Joe Dugdale
Hey fellas, got an issue with my rx1 thumbwarmer... Seems like it goes to full power, or high and cannot be adjusted...so hot, it can barely be used... When trying to adjust on handlebar control, I don't even get a readout on the display... Did some reading, and thought it was cdi related... Swapped out with another.. Same thing.... Removed switch, and with the tester, there appears to be continuity when adjusted... Tested wires from cdi back.... Appears to be none broken as I was able to complete a circuit with tester.... Help please???
Joe Dugdale
I have 13.8 volts to both wires at thumbwarmer switch plug when idling, switch works as it should when I plug it into handwarmer, it controls them fine......
