Barrett hodgson
Hi everyone
I bent up my skid on my nytro pretty bad (track came loose and screwed it all up)...bought a skid off the part out but the mechanic is now saying the one I bought is also tweaked and he doesn't want to install it...i need to get a skid soon because he wants it out the shop, and I can't find any other nytro skids online, so my question is
1. Is the skid on the nytro the same skid as any other sleds, i.e. The vector
2. Do any other skids bolt up (even if they aren't necessarily the same)
Thank you very much
Thank you very much
theCATman
Any skid will go in, it's a matter of where the bolt/mount holes are & if new ones will need to be drilled.
That said, a Pro-Action or Monoshock out of a Vector or RX1 will fit fine, but new holes may have to be drilled.
You won't be able to use the dial adjust of a mono either without either opening a hole in the side of your tunnel, OR buying a square key from Barn of Parts to adjust the shock without the cable & dial.
Sent from my SM-G930R4 using Tapatalk
theCATman
A Pro-Active from an '05 Vector would be another option.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I have whole skids if need something yet.
