06 Yamaha GT correct Primary Clutch
If you haven’t already checked the part number on your clutch, you may want to do so. On the outer clutch cover, between the tower/2 bolt areas and the center bolt, you should see the correct ID number 8FP00. If you find the incorrect number 8FN00 take the sled to the dealer and get the correct primary installed. Remember P is correct and the N is wrong. Yamaha should have contacted all owners last year but some may have slipped through so I would suggest just to be sure you make a quick check.
Ref: Snow Tech Sept 2007
