MRFUSION
- May 19, 2008
- Peace River Alberta
- 2011 Custom Built Nypex
2008 Custom Union Bay 980 MM Chassis
I have an 07 Phazer I’ve acquired. It starts and runs good, it will not rev past 8700-9000rpm. Bottom end pulls strong, just the engine surges, on the stand or testing it’s the same. Fuel pressure okay, it’s not the tors as it’s bypassed. been a lot of hands on this in the past. Sleds been around. It had a turbo once but has been removed. Cam timings on, strong spark.
Any ideas would be appreciated
Thanx.
Thanx.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I'd be looking at the clutching. Since it used to have a turbo, it might still be clutched for it.
MRFUSION
- May 19, 2008
Yah it was but I corrected it to stock setup. Had another crack at it today. Up to half throttle smooth end will build rpm to like 10,500, if you open it up all the way just drops down to like 8700 and engine surges badly. Removed clutch so no load and same thing, it’s not like a rev limiter. It’s weird. I have swapped out TPS, injectors, rail, regulator, plugs. She’s a beauty!!! Haha!!
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Maybe I'm old school, but I've always heard it's not good to rev an engine that high without a load on it. Sounds like it's running out of fuel though.
MRFUSION
- May 19, 2008
Yah agreed, I’m at that point tho.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Maybe fuel pump or clogged filter?
07mcxpz
- Feb 11, 2016
- Southey
- 07 mountain lite mcx
11 apex se
i know its a long shot but did this ever get solved. i have same sled same problem. only it still has turbo on it. exact same thing under load or on the stand wont rev past 9500. the amount of things tried and parts swapped has me just about at wits end!!!!
You're watching the fuel pressure as it's doing this surging?
07mcxpz
- Feb 11, 2016
- Southey
11 apex se
Yes it’s 42ish pounds and goes to 60 under boost. That was a while ago and will be rechecking again.
Have you changed the cam sensor? Usually it will misfire more than surge but worth a try. It is what affects fuel injection timing.
07mcxpz
- Feb 11, 2016
- Southey
11 apex se
Swapped it with a different one and same thing. It is more of a misfire in my case. But same rpm. Wiring issue to that sensor will show on diagnostics right?
Should yes.Swapped it with a different one and same thing. It is more of a misfire in my case. But same rpm. Wiring issue to that sensor will show on diagnostics right?
The used one was from a good running machine?
07mcxpz
- Feb 11, 2016
- Southey
11 apex se
No I cannot confirm that. Is there a resistance test or something I can test it by. Like changing ohms when a magnet goes by or steel?
I don't know the numbers for that. I had this happen once on an R-1 street bike, and it turned out to be faulty even though it wouldn't throw a code and diagnostics showed it to be good.No I cannot confirm that. Is there a resistance test or something I can test it by. Like changing ohms when a magnet goes by or steel?
The part does update to a new part number.
I'm not saying for sure it's your problem, just giving you things to try.
