Sidewinder146
- Jan 10, 2017
- Newfoundland
- 2017 Yamaha sidewinder
I have 650 miles on my sidewinder xtx-se 141, it has 21/41 gearing. On good trails today I could only pull 100 MPH max(speedo) , my rpm was at 8800, and my belt shredded. Clutches were very hot, almost seems like it isn't shifting completely out for top end. The track is 141X1.6" so I'm not expecting to get the same speeds as the shorter track versions. Should I be maxed out at 99-100 mph ?Any input would be appreciated !
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
New rollers? My sled is a ltx and I blew a belt the exact same way. I then put the cat rollers in and changed the secondary spring position. I got a bit more top end. But the shift felt better and the clutches where cool.
Sidewinder146
- Jan 10, 2017
- Newfoundland
I have stock rollers. What secondary spring position did you use?New rollers? My sled is a ltx and I blew a belt the exact same way. I then put the cat rollers in and changed the secondary spring position. I got a bit more top end. But the shift felt better and the clutches where cool.
Sidewinder146
- Jan 10, 2017
- Newfoundland
Does anyone know the number on the cat rollers?
Arctic cat rollers 0648-824
Sidewinder146
- Jan 10, 2017
- Newfoundland
Thank you!Arctic cat rollers 0648-824
MDGFLHR
What did you wrap your secondary at?
Add the same experience last Saturday. What a mess...
I put cat roller and put the secondary from 3-3 to 6-1 to get higher rpm
Envoyé de mon SM-G935W8 en utilisant Tapatalk
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
I ran 101 on a BTX LE and got 1100miles on my belt installed new now just because you xtx guys should hit over 100
- Apr 14, 2003
- Hessel, Michigan
XTX SE 21/41 gearing running 126mph so far (I have EVP's stage 4)....
Shagman BTX LE already hit 108mph stock other than clutching.
DC5
Speedo or GPS? Speedo seems to be 3-4mph high.XTX SE 21/41 gearing running 126mph so far (I have EVP's stage 4)....
- Apr 14, 2003
- Hessel, Michigan
GPS on phone.
Speedo read the same.
I have a GPS mounted on the SW now for this weekend.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Nice to see you made it over here Martin. There is lots of info on here about the belt issues. I feel this issue will get solved and we can put it to rest. Shagman, NOS-Pro and Dalton Ind. I would follow.
Troy -journeyman
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Joe,you still running stock secondary spring,and you now have it wrapped at?60% 70%New rollers? My sled is a ltx and I blew a belt the exact same way. I then put the cat rollers in and changed the secondary spring position. I got a bit more top end. But the shift felt better and the clutches where cool.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I still have it wrapped at 6-1. I've seen like 115 mph. No marks on the spring. Clutches had a bit of brown on them in one spot.Joe,you still running stock secondary spring,and you now have it wrapped at?60% 70%
- 32K
