NytroBite
- Nov 30, 2014
- Stevens Point, WI
- 2010 Nytro RTX
I've done lot of research on bigger idler wheels but still kinda confused about the 6205 bearing on the stock Yamaha outside rail mount... Can it simply be bolted on or does something need to be done because won't the end of the mount be slightly inside the bearing instead of being flush. Sorry if it's been covered just can't find it or picture it
Grimm
You'd be best to fill in the void with a large washer or two.
NytroBite
- Nov 30, 2014
- Stevens Point, WI
- 2010 Nytro RTX
A washer that would fit inside the bearing or is the wheel offset different and you need to add washer on the shaft of the mount behind the wheel just trying to figure out everything thing I need to take to get it put on
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Best would be to use Excell 135mm Xwheels.
About the same price as Doo wheels and nothing to change. You can even use them on the inside suspension locations.
Yamatario
- Jan 8, 2009
- SW Ontario
- 2018 LTX SideWinder
2015 Viper LTX DX
2009 Nytro XTX
I switched out years ago to the Excel 135mm wheels, work great.
Grimm
A washer inside the bearing will work. The end result is that the wheel will sit 1.5mm further out, which isn't a problem on outside of the rails.
