olivia317
kirkswim
- Jan 11, 2009
- sudbury ontario
- Yamaha RXWarrior
There is an aluminum adapter that Yamaha sells for the proaction skid for these wheels. It is intended to replace the plastic bushing so that you can run the newer style apex wheels(which use the same bearing)or when running the Yamaha aluminum wheels. I currently have these on my 2005 Rx1 Warrior with stock sized wheels and it made a huge difference in slider wear. Those darn plastic bushing have movement in them even when the bolt is super tight. The aluminum adapter fixes that and holds the wheel more true.
Maim did a write up here:
http://www.totallyamaha.net/forums/showthread.php/97325-idler-wheel-bushings-mod-proaction
olivia317
Exactly what I need. Thanks!There is an aluminum adapter that Yamaha sells for the proaction skid for these wheels. It is intended to replace the plastic bushing so that you can run the newer style apex wheels(which use the same bearing)or when running the Yamaha aluminum wheels. I currently have these on my 2005 Rx1 Warrior with stock sized wheels and it made a huge difference in slider wear. Those darn plastic bushing have movement in them even when the bolt is super tight. The aluminum adapter fixes that and holds the wheel more true.
you are welcome! those damn things drove me nuts before i found the fix too.
olivia317
Tried to order them with no luck. Out of stock though Yamaha. Haven't found any yet. Still stuck with the plastic bushings.you are welcome! those damn things drove me nuts before i found the fix too.
dang. i might have a set in my parts pile still but i need to check 1st.
kirkswim
- Jan 11, 2009
- sudbury ontario
- Yamaha RXWarrior
Next time I have them apart I could measure them and let you know the measurements so you can have a machine shop make you some.
olivia317
Actually found two of the Yamaha bushings new in the bag. Gonna copy them when they get here. Thanks!
kirkswim
- Jan 11, 2009
- sudbury ontario
- Yamaha RXWarrior
No problem I was just thinking about going into garage tomorrow and taking one of my dad's venture to measure one.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
i have some of the plastic bushings and a couple of the alum ones if you need them.
olivia317
Got it taken care of, thanks.i have some of the plastic bushings and a couple of the alum ones if you need them.
