SWTURBO
Over 1500 miles on Sw 137 Le and not a hitch and was TD enhanced from day one . Did blow one belt at 800 miles but that was my fault. Must say it is everything I hoped it to be from early April till now ! Awesome gas mileage and torque.
SRX Boy
Which version did you go with? Did you change weights, gears and muffler???
Sent from my iPad using Tapatalk
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Can i ask what YOU did that blew belt? How was it your fault? Just gathering info for my future fix
SWTURBO
Two long rips down the lake then one more long pull in a bit of deeper snow way too much stress on the belt. Imo.
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
If you don't mind me asking what was your awesome gas mileage? I have same sled sw 137 le and I'm not getting very good mileage at all! 105-110 miles per 30-33litres . Last too tanks were pretty much the same and all trail riding never going over 48mph mostly mid 30's. Not once on either day did I open it up.Over 1500 miles on Sw 137 Le and not a hitch and was TD enhanced from day one . Did blow one belt at 800 miles but that was my fault. Must say it is everything I hoped it to be from early April till now ! Awesome gas mileage and torque.
SWTURBO
I'm gasing up with 1200 Doos at pumps and only 2 to 3 dollars difference probably running 14 -16 mpg cruising speed
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
That's 16 miles to an imperial gallon.
Pretty darn good I would say for a 200 hp sled.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
My TD tune with turbo force muffler has been flawless. Fine tuned my clutching and it's just amazing when you hammer it. I was nervous about a flash from day one. I did my research and went with TD on my first turbo sled. Ben and TD did a great job for a first year motor.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
We did our homework and did very safe tunes. Now its time for more powerful tunes. The motor has been flawless for us. 245 sleds flashed now some with 12000km.My TD tune with turbo force muffler has been flawless. Fine tuned my clutching and it's just amazing when you hammer it. I was nervous about a flash from day one. I did my research and went with TD on my first turbo sled. Ben and TD did a great job for a first year motor.
Couldn't be happier about the platform. It has been so painfree for us I mean, we have had to do so little tech support. The few I have seen needing tech were boost leaks very simple fix.
http://www.turbodynamics.ca
sledding rocks
i also from day 1 put the td power trail tune in , this sled is crazy fast n fun , 1500miles with no issues , will be putting on another 1200 miles next week , i have seen 141mph on the speedo , radar at 137mph , i have owned 2 11oo turbo with td programs and a big turbo from tt3 , this sidewinder by far is the fastest pump gas tune to date thanks to td , the same speeds that i have achieved on pump gas i would have needed race gas or meth on my 1100 turbo ,
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
Impressive numbers!i also from day 1 put the td power trail tune in , this sled is crazy fast n fun , 1500miles with no issues , will be putting on another 1200 miles next week , i have seen 141mph on the speedo , radar at 137mph , i have owned 2 11oo turbo with td programs and a big turbo from tt3 , this sidewinder by far is the fastest pump gas tune to date thanks to td , the same speeds that i have achieved on pump gas i would have needed race gas or meth on my 1100 turbo ,
PowderFalcon
Pinnin' it!
impressive!! that's some good gearing!
sledding rocks
yup , thanks to you , can't wait for more boost . lol
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Installed my ECU with the powertrail flash today. First time I turned the key I had an SD 84 code come in which is TORS. Started the sled and let it warm up, re started it a few more times. Alarm is gone just curious why it came in on the initial start?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I do believe I had that also. Never saw it again in 1800 miles
- 46K
