FxNytro2010
I have a base model 2015 Viper MTX 153 with the HPG coil springs shocks and I want to add the new OEM 2016 front end package. Does my coil spings shocks need to be changed ? If so, can it be shorten or I really need to buy new shocks ?
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
If going from 2015 40" wide to 2016 38" wide, then yes, you will need to have your sucks shortened. I went from 42" to 2016 40" and had spacers stalled in my Floats and they work great. Shock length for 38" is 17.1" CTC extended. For 40" it is 17.9" extended, and for 42" it is 18.6" extended. The cat coversion kits come with spacers I believe.
Yes you will, the Cat 2016 kit does come with spacers but from what I understand they are for the Fox Floats. With our 365 kit you can use any and all the factory shocks with any modifications, or the need to buy new shocks at all. The 42" 40"38" and 36' wides front and shocks will work with our kit. www.barcodeperformance.com
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Cat now has a 38" width kit with the 16+ spindles so you can reuse your shocks and lower arms if you don't want/need the 36" width.
