mrt
Hi,
I bought a 2007 phazer with a blown motor.
1. what is the fastest, and least amount of work to remove the motor. anyone have a detailed instrustions of what to remove to take out the motor. how long should it take. any help would be appreciated
Jory
- Mar 20, 2016
- Alberta
- 2007 Phazer MTX SC
Pretty easy if you're mechanically inclined. Download the manual, it's free. You will need a clutch puller but the rest is straight forward and you only need a few tools.
I just finished rebuilding mine so if you're stuck and need advice I'll be happy to answer as best as I can.
Sent from my iPad using Tapatalk
mrt
I have the manual, I haven't looked at it yet. just wondering what body panels have to come off. I saw the paragraph about removing the motor. it didn't say about the body panels, just wanted to know what was involved before that
Jory
- Mar 20, 2016
- Alberta
Just start from the top and work your way down the panels. 10mm bolts, twist locks and Allen bolts on the lower panels.
