Joshua moskal
- Jan 18, 2016
- Jackson, mi
- '09 nytro xtx, '03 rx1, '02 mxz700, '01 550 sport touring
I purchased an 09 nytro xtx at the end of last year and stored it properly. Just pulled it out yesterday to get ready for a trip in a couple weekends and won't start. When turning the ignition I hear the fuel pump engage but nothing else happens. I'm getting a click at the starter relay and periodically I will get clicking at the ecu in the wiring harness and that will click 17 times. While the ecu is clicking the headlight and taillight keep flickering. Any help or advice would be greatly appreciated. I have already ordered a new starter relay in hopes that the issue but if not I could use some assistance.
How is the battery? 7 year old sled with original battery? I would look into the battery first and then start looking at the different electrical components.
Clean grounds are also very important.
Joshua moskal
- Jan 18, 2016
- Jackson, mi
Nearly positive it's a brand new battery from last year. I'll swap out a battery and double check just to make sure though.
cowwyy12
- Nov 29, 2014
- 2008 Yamaha Nytro 1000cc 4 Stroke
I would start with the starter relay mine used to just click when I tried to start it especially in the cold. I changed that and haven't had that trouble again. Good luck
