Here is a option to extend your 128" Apex to a 136" The following is a list of parts you can buy to do this.
Side view of the small tube extension we added to cover the heat exchanger.
Underside view of the small tube extension.
Had to move the track adjusters to maintain the same distance from the rear axel to the adjuster.
Track USA sure makes a nice billet rail extension. Great Fit and Finish.
- I opted to use a 9191H Ice Attak XT 137 x 15 x 1.22, 2.86" pitch, Pre-Studded, Full clipped tracks
- To use the above track I need to change the drivers to the 2.86 drivers from Yamaha ( 8HK-47531-10 and 8HK-47532-10). There are handed drivers so you will need both listed.
- I also used the extension plate (8HN-21917-00-00) and bumper (8HN-77541-00-00) from a Apex XTX as well as a heat exchanger (8HN-1241A-00-00)
- Tracks USA Rail Extension: YAM-AP-2044" Rail extensions for 2010 to 2014 Yamaha snowmobiles with hollow rear axle. 121" to 128", 128" to 136"
Few more pics and the final build.
We added extra hyfax saver wheels to a few key areas. Also added the extra rear idler to the outside rail between the rear axle and rear arm.
Since there were very low miles on the sled, we pulled the dust covers off the speedo side lower bearing and repacked the bearing.
Changing out the track and drivers.
sheetwright
Just had Ulmer do the exact same thing with mpi boost, and full hygear suspension front and back on my 2012
Awesome... fairly easy to do too.
sheetwright
Tom what did you think of the 136" and the EPS together? Did you get as much push as the older models (Attacks)? I'm running 13mm sway bars, C&A skis, and dual rate springs with a 136" setup on the EPS, and was running into a lot of ski lift with the 128" alone on stock springs. Trying to get her to rail flatter..... a little slide with the push is ok, but push, and lift sucks IMO
Its not much different as far as push. I run my Floats on 65psi and that keeps the front way down. I also had the rear spring changed and re-valved by Pioneer in my 128-136 sled and that keeps the front down with less sit in at the rear. Main goal is to try and get the front A-Arms straight across to get it to work the sway bar faster.
sheetwright
I see. Well we will see this weekend. Heading to Watersmeet to try it out. Thanks for the help
No Problem... I will be in Ishpaming Area riding as well and I will have my computer so keep me posted.
canadian nytro
- Dec 3, 2009
- Port Perry, ON
- 2011 Yamaha Apex
2002 Yamaha Viper
Could you have used a 136" vector extension? Oh and why go to a 137 vs the 136 which would not have required swapping the drives? What are the benefits? I'm going to be changing my track this summer and was thinking about going to a 136".
No it does not fit. The 137 track is a 2.86 pitch that's why the difference in 1 inch. The rail and tunnel extensions are the same it's just the length of the track. The only reason I decided to use the XTX extension is because it is relatively cheap and easy to use.Could you have used a 136" vector extension? Oh and why go to a 137 vs the 136 which would not have required swapping the drives? What are the benefits? I'm going to be changing my track this summer and was thinking about going to a 136".
Trailblazergt
- Mar 21, 2013
- Pincourt, Quebec
- 2008 Apex LTX stretched 144
Why did you change the drivers,
Just curious if there was an advantage to that, I recently swapping my track for the same track but a 144" length from Tracks USA using stock pitch drivers and extended the tunnel and custom made rails to accommodate the same monoshock suspension.
JG
JG
The drivers were only changed because of the pitch of the track that I was putting on. Standard pitch for a Yamaha track is 2.52 and I went to a 2.86 pitch track.
gvessey
- Feb 8, 2015
- 2017 Sidewinder LTX-DX
2011 Apex SE Supercharged (Sold)
Hey Tom
I have the same sled, supercharged. Just wondering if your setup will work with the 144" tracks USA rail extensions / XTX extension, and I am also curious why you had to replace the stock rear cooler. Mine is in storage and I hadn't looked to close at it to be honest, but I figured it could be just moved back.
Hey Tom
It would work great for a 144. The problem with the rear cooler is once you move it back the tubes are not long enough and you would need to make or modify the sides to pop the cooler tubes thru and then figure out someway to user the rear tube covers.
- 146K
