Kelly1507
hey guys just looking to see if anyone is running drag n fly heel clicker clutching in the apex xtx. I want to install my kit but can't find any info for this sled setup. Any help would be great
evil eagle
I've been using them for years. Now I have them in my 3rd apex. Are you looking for exact set ups?
Kelly1507
Yes I am. I had this kit in my 07 rtx and it rocked. You think I should just try them first to see where I stand?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I have a set up for the attack. I will post when I get home
Kelly1507
I don't need a Attack setup I need a apex xtx setup. ThxI have a set up for the attack. I will post when I get home
STAIN
- Feb 29, 2004
- Vermont
- Vermont
should be close
Adding a Supercharger as well?
Kelly1507
Whatever makes your package look bigger. LolAdding a Supercharger as well?
brother did my 2011 but mine is clutched for off trail and started at the same settings as he did on his 05 rx war. i need more tip weight as it hits the limiter in powder but hooks like an animal on trail.
running a 50/41 dalton helix with stock secondary spring. primary, black spring with 5 grams of heel weight and about 2-1/2 grams in the tip. had to go to hardware store to get heavy enough bolts for heels.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Go to the hardware store and get some 1/4-28 allen head set screws for finer adjustment than what is included in the kit. I have 4 different lengths.
Stock secondary
Black hc primary spring
bolt + washer in the heel
bolt in the center
1/2" set screw in the tip
bolt + washer in the OD
Total weight 73. 0 grams
This is a proven set up for the Apex. Slight tuning may still be needed for you application. I actually tried a Softer secondary spring, sliver I believe, in a short track and it worked very well
Stock secondary
bolt in the center
- 6K
