garcenw
I recently acquired a 2013 Nytro RTX. I did a search on this issue and found a few threads with the issue expressed, but there was no definitive answer.
There is an issue with the rebound adjuster on the center shock when I tried to adjust it. Starting with the knob turned all the in, as I back out, I feel 2 clicks, then it spins freely for about 1.5 turns. In this 1.5 turn zone, you feel no clicks until you get near the end and then you feel 3 clicks. Is this simply an issue with the detent mechanism and the rebound is still adjustable or is something wrong with the rebound circuit?
Thanks.
- Walt
Thanks.
- Walt
