Canuguy
- Dec 13, 2015
- New Brunswick
- 2014 Viper LTX-SE
Bought this as brand new leftover last season. Got 2000kms (1200 miles) on it now and still find the rear suspension super stiff. Any ideas/suggestions?
Sent from my iPad using Tapatalk
Yamacat21
Gain some weight!
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
- 2019 Yamaha Sidewinder X-TX LE 141
Gain some weight!
How about ride those rough trails faster?
Canuguy
- Dec 13, 2015
- New Brunswick
- 2014 Viper LTX-SE
Have tried both - been gaining weight steadily over past 10 years
Have also been driving more aggressively the older I get but this LTX suspension is crazy stiff...
Yamacat21
I'm an honest 240 dressed, and do see that it is stiff for most riders, I ride very aggressive so prefer a stiff skid, I would suggest revalving shocks and setting all springs to the lowest setting, you can take up on limiters but may find handling issues doing that.
Studroes144
Biggest favor you'll ever do for yourself is pull the rear shocks out and send them to Cannondale27 to get proper valving done. You'll be amazed at the difference, I'm sure he'll chime in here soon.
PM me best $80 per shock you will ever spend.
ck7923
PM sent.PM me best $80 per shock you will ever spend.
Canuguy
- Dec 13, 2015
- New Brunswick
- 2014 Viper LTX-SE
Where are you located (I'm in Canada), plus what kind of turnaround time, and finally, how easy/difficult is it to remove shocks to send? I suspect I'll wait till sledding season winds down before I have the shocks rebuilt and hoping my back can handle it for remainder of season. Can you send me your contact/location inormation?
Steve SpieringWhere are you located (I'm in Canada), plus what kind of turnaround time, and finally, how easy/difficult is it to remove shocks to send? I suspect I'll wait till sledding season winds down before I have the shocks rebuilt and hoping my back can handle it for remainder of season. Can you send me your contact/location inormation?
4918 County Road B
Manitowoc,WI 54220
(920)323-1973
C27 Shock Doc on Facebook
3 day turnaround unless Snowmobiling
Thanks Steve
scott bardwell
- Jan 5, 2015
- Ontario, Canada
- 2017 Yamaha Sidewinder LTX DX
I
I found putting softer cat springs in helped a lot as well. I also ended up upgrading the rear skid shocks to axis shocks.
trailtamer
- Feb 8, 2006
- Manistee County, MI
- 2014 Yamaha SR Viper LTX
Cannondale rebuilt my shocks and did an awesome job. It is a huge improvement, but I still feel the springs are way too stiff for my liking. I ordered a dual rate spring (an Arctic Cat part) for front track shock and new (2016-17 Yamaha Viper LTX) torsion springs that are a softer spring. Waiting for all parts to arrive so I can install everything at the same time. There are numerous threads here about the LTX rear suspension, try using the SEARCH TOOL. Happy reading.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
All of the Cat springs are currently on back order:
(#1704-736, #2704-026, #2704-027)
$150 for all 3 plus shipping
You can however order a true dual rate front spring from Hygear:
(https://www.hygearsuspension.com/co...s/center-dual-rate-pro-series-spring-kit-snow)
$179 plus shipping
The other option is to get the torsion springs from Hygear as well:
(https://www.hygearsuspension.com/co...aha-viper-ltx-arctic-cat-xf-137-pair-modified)
$169 custom tuned to your weight
What are the part numbers for the 2017 LTX torsion springs? I cant seem to figure out which model to select from the parts fiche.
$179 plus shipping
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
FYI - CountryCat jsut got a shipment of springs. They are in stock again!
2 Front Springs Left:
http://countrycat.com/ccstore/index...04-736-spring-comp-90-250-x-8-25-ptd-blk.html
1 Each of the Rear Springs Left:
http://countrycat.com/ccstore/index...-spring-susp-394sq-90d-16-5lb-rh-ptd-blk.html
http://countrycat.com/ccstore/index...-spring-susp-394sq-90d-16-5lb-lh-ptd-blk.html
Canuguy
- Dec 13, 2015
- New Brunswick
- 2014 Viper LTX-SE
Thanks for all the support- I have some options now. Will probably wait till the season is over to resolve. Appreciate the helpful advice!
