Dougie Fresh
- Mar 4, 2015
- 2014 Viper XTX
I am trying to replace the knuckles on a 2014 Viper XTX. Long story but they are marked up pretty bad removing sled from tracks. I purchased new ones and am looking for advice on replacing! It appears the upper and lower arms are pressed into the knuckle ... correct? What is the best approach to free these up?
Loosen the nut on both,get some upward pressure on upper arm with jackstand on ground and arm on stand shock still in, give spindle a whack right by lower joint. After that one is loose do same for top then remove the nuts.
