North Bay Ned 691
I have a brand new 2016 VK Pro with only 66 km on it. Was driving around 40 km when it started to make an awful noise from Drive train. Sounded like studded track was hitting tunnel. Thought maybe ice had built up so I put it in heated shop over night. Checked the track tension and its good. Checked chain case tension and that is good. Changed the belt but the noise and vibration persists. Noise happens in Drive gear, low gear and reverse. Also occurs with rear of machine suspended off of the ground. Noise does not occur at idle only when clutches engage and track gets turning. Dealer is closed until Wednesday any ideas would be appreciated.
Thanks.
Thanks.
sounds like a bad bearing in the drive train or one of the wheels.
North Bay Ned 691
Thank you. I noticed some free play on Secondary clutch on horizontal movement about 1/4 t 3/8 of Inch that my buddies 2010 VK does not have. Patiently waiting until RL in verner opens Jan 04. This sucks! Thanks again will keep you posted.sounds like a bad bearing in the drive train or one of the wheels.
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
- 1997 vmax 600 sx, 99 venture 600, 2004 vk 540, 2006 Yamaha vk pro, 2009 venture multi purpose and 2006 venture 500 xl current ride 15 rs viking pro
check your track tension, if it's too tight with those extrovert drivers it will cause a vibration, for some reason some dealers can get the track tension right! A buddy of mine just bought a 2017 vk 540 and complained he had vibration and like the sled was always was laboring all the time, we checked the track tension and it was way too tight! We slackened the tension and all was good. cheers!
dixopr
- Apr 28, 2015
- FGH
- VK pro 11
Nytro mtx 08
How is the 2017 vk540? I checked one out and man is that a simple machine. I've told all my trapping friends to check it out before buying another brp skandic. I
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
Definitely a big improvement in comfort , ride and deep snow abiltiy, the fuel economy is still uncertain as of right now!
dixopr
- Apr 28, 2015
- FGH
- VK pro 11
Nytro mtx 08
Wind protection looks superior as well. Please report on fuel economy when you have some miles under your belt.
North Bay Ned 691
Thankscheck your track tension, if it's too tight with those extrovert drivers it will cause a vibration, for some reason some dealers can get the track tension right! A buddy of mine just bought a 2017 vk 540 and complained he had vibration and like the sled was always was laboring all the time, we checked the track tension and it was way too tight! We slackened the tension and all was good. cheers!
North Bay Ned 691
Turns out when they studded the track they put in a tunnel/heat exchange protector and for some reason a welder let go and it then hitting the track. They put in a flat bar protector instead and that noise I gone. The issue now is it is very very loud. To the point my wife will not ride on it. Not sure why it is so loud now. Wishing I had bought the 900 Skandic. Not impressed at all!
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
Is the sled still under warranty? Even if is not, sound like the dealer messed up! Return the sled to the dealer so he can fix his mistakes, Don't let his mistakes reflect on the sled, the vk pro is a well built sled, had one for 20,000 kms never let me down or left me stranded which is something brp sleds can't do! Hope it works out and you get to enjoy the pro! cheers!
dixopr
- Apr 28, 2015
- FGH
- VK pro 11
Nytro mtx 08
Totally agree, we've had a bunch of Skandic sleds from the new generation go down up here for various reasons. The VK Pro is built better hands down, does it ride as nice as a Skandic for 2-up? no. But I have yet to see a yamaha 4-stroke have engine problems. Get your issues sorted and enjoy.
Have 1400km on my new vk 540... ran her out of gas at 270 km , about twice as far as the older 540.. liking her so far, love the new upgradesWind protection looks superior as well. Please report on fuel economy when you have some miles under your belt.
Gyukonrick1
- Jan 11, 2017
- Ottawa Ontario
- 2016 Yamaha Venture TF
Good luck with Yamaha.
I bought a brand new Venture. Has the same resonating noise between 45-65 kph. Yamaha Canada told my dealer that they were aware of the problem but they had no remedy. Told me to "drive over or under those speeds".
There should be a warning or a disclaimer before you buy these sleds. I sold mine with 120 miles on it and took a good loss.
- 32K
