evil eagle
what is this?
musselman
- Apr 17, 2009
- Fenelon Falls, Ontario
- 2019 Ren XRS 900T, 2010 Nytro RTX
It connects the 2 front shocks and lets oil flow between them. Helps with non symmetrical bumps and cornering.
UP Michigan rider
Hooray bold new colors!!
UP Michigan rider
- Yamaha Reactive Suspension System (YRSS) on Apex models
- Exclusive Yamaha technology that connects the two front shock bodies hydraulically
- Helps control lateral roll without compromise to bump compliance and comfort
- Improved ride quality with more precise handling over conventional shock absorbers
evil eagle
I wonder if it actually works. Unlike the single shot does before the shock upgrade.
UP Michigan rider
UP Michigan rider
More crap to go wrong in the long term.
snowman 700
- Oct 10, 2005
- Mid-Michigan
- 2011 Apex SE
2012 Vector (wifes)
I wonder how hard to rebuild or durability of hoses? What do you think Cannondale27?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Very cool. Kind of like a hydraulic sway bar. The Toyota 4 Runner has a similar system
sgauthier
Would those be OHLINS ?
kinger
Guys this is AWESOME mod to the apex, its very trick and will make the best apex ever. I wish I could adapt this to older units. Have any of you ever run with the sway bar disconnected just to try it? In the straights its so cushy having full independent suspension. Its just not able to corner at all. This system will allow more like a non-sway feel in the straights but with valving to help stiffen it up in the corners. This is way cool tech to have in a sled. Combined with EXUP, powersteering, I don't see how anyone would like to ride anything else on the trails!
5valve
- Feb 3, 2013
- N. IL.
- Nytro, IQR, Redline’s, trailing-arm Polaris’s
I wonder if this is the result of the Karpiks hiring? Makes me wanna pass on a new "left-over" and Spring Check a new one.
sgauthier
I would think you could retro fit that on any apex. I'd be scared to ask how much it would cost thou
gytr done
- Jan 8, 2015
- Rx1
More overstock parts from other divisions, what a joke!
gytr done
- Jan 8, 2015
- Rx1
HAHa
