max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
On top of pump there is 2 male spade connectors, most shops just put crimp on individual female connectors.... which one of mine poped off.... dont know why i did not go BOOOM as it would have arced, but thankfully it didnt.... got the proper fitting pig tail that locks into pump... soldered and heat shrunk the connection to factory harness on under side of gas tank banana lid. much safer and way it should be done.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Imagine my surprise when I pulled the pump out and found those two cheesy female connectors that they installed, Quite shocking really.On top of pump there is 2 male spade connectors, most shops just put crimp on individual female connectors.... which one of mine poped off.... dont know why i did not go BOOOM as it would have arced, but thankfully it didnt.... got the proper fitting pig tail that locks into pump... soldered and heat shrunk the connection to factory harness on under side of gas tank banana lid. much safer and way it should be done.
I'm not mad, but how much more could they have charged us to put the correct connector on there. $1.?!?! Lol.
I wish they would have offered it to me. Lol.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
A good tight connection on the terminal is what is needed.
The plug in can still have a loose connection and cause arcing.
Some of the run issues on these sleds are caused by loose connections and are not found until the plug melts.
Having a good tight spade terminal is just fine.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
if all that is available at the time is the spade connectors , i would squeeze them tight and then once installed, maybezip tie them dwn or fill cavity with sealall.... ment for being saturated in fuel full time.
Doc Harley
- Oct 17, 2016
- Here & there
If it was good enough for the engineers and the loss prevention team at Cat, it's good enough for me. Hahaha.A good tight connection on the terminal is what is needed.
Turboflash
- Mar 18, 2019
- Southern MN
You're good. Misinterpretation on my part.That picture is exactly what my kit is. I’m not sure what you’re trying to say about connector. Is it like a jumper harness you have?
Doc Harley
- Oct 17, 2016
- Here & there
These flex fuel lines are pretty cool. End needs to be lightly & evenly heated with a torch, until you see a wetness in the plastic, a very small puff of smoke and then she'll go. This allows it to get around the barbs, then finally as it's cooling it forms the shape of the barb. Not going anywhere.
REDLINE 1
I just reused the original flex hose that was on the stock setup. I added a hose clamp at each end for extra measure
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, I would have, had the torch not gotten so close to the plastic and blast a leaker in it. Lol. Sucks to be me.I just reused the original flex hose that was on the stock setup. I added a hose clamp at each end for extra measure
REDLINE 1
This is the plug I got for my walbro pump. They have them on Amazon or summit also
Doc Harley
- Oct 17, 2016
- Here & there
Yep, saw that too. It was like $12. Should have did that as well. Decisions, decisions..... hahaha
