@123
thks i will try itI have the 60 gram base weights(62 grams actual)
Stock I had 2 washers in the heel, a tungsten and 2 washers in the tip. Your starting out lighter, I'm not sure how the profile compares to the 60s.
I would try 4 washers in the heel, 2 washers in the mid and 6 washers in the tip.
@123
hi just want to know how you shim for coil bind? thksPulled my secondary apart today and am now showing signs of coil bind. Shimmed the helix as per shagman and wrap set 6-1 so we'll see how she goes either tomorrow or Thursday. conversation with ulmer about primary slipping on top end, his answer " coil bind in secondary". He also indicated he has a new secondary spring to be released this week and an update to his clutch kit which includes secondary spring and helix.
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
check this thread and others on shimming, coil bind, blown belt. this one has pics.hi just want to know how you shim for coil bind? thks
http://ty4stroke.com/threads/helix-shims.147201/#post-1350811
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Delete
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
that's like 10 bucks free shipping American right?
