Dan3636
Hey guys I have 2020 146 sidewinder running a max 20 Td tune. I think the belt is slipping on take after installing clutch upgrades . I installed all of this at once . 911 clutch cover, blue an orange primary spring,Iam running 2 glide washers, secondary spring black an orange with 35 degree helix with belt adjuster with float . After installing all this on take off it slips belt an takes off an runs fine. Any thoughts? Is this a happy clutch set up? An slight scaring on primary spring with maybe 8 to 10 passes on set up .
justinator
What belt are you using? What holes is the secondary spring in?
Do you have the belt height set properly?
Dan3636
The spring is set to 6-1 an belt is even with the secondary Sheve thanks guys
Dan3636
Running 8jp belt.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
8jp with your set up imo is not a good thing. Ultimax or g force redline is what I use. I dont Have a tune but the 8 jp is a dirty belt
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
What version b/o do you have. From what I understand you want 6-3.The spring is set to 6-1 an belt is even with the secondary Sheve thanks guys
Dan3636
I would say the most to date. I just bought it from Td 4 weeks ago. How can u tell?
justinator
I dont have much experience with 8JP but 6-1 is the recommended wrap on the first version of the black orange spring. The new version which is what you will have since you purchased recently is recommended to be wrapped at 6-2, alot of guys use 6-3.
Only time a belt will slip in secondary at take off is if it is getting stuck and not returning to the top when you stop, you will hear a little chirp/squeal when you take off. If your feeling more slip then that it is likely coming from the primary.
Dan3636
Yeah I just installed 911 cover an new primary spring as well something is definitely going on. The inside sheave gets super hot just letting sled idle?I dont have much experience with 8JP but 6-1 is the recommended wrap on the first version of the black orange spring. The new version which is what you will have since you purchased recently is recommended to be wrapped at 6-2, alot of guys use 6-3.
justinator
Have you measured your offset? What weights are you using in the primary?
Dan3636
No have not measured offset cus Iam running the floating secondary now . Should I still measure the offset ? Iam running dalton weights in primary. Thanks
justinator
Yes still measure offset. Typically the clutch needs to be pushed in towards jackshaft to achieve correct offset and alot of the times this requires machining of the secondary clutch . Make sure belt is removed when measuring offset.
