Yamahaaddict08
- Dec 11, 2016
- Maine
- 2008 Yamaha Fx Nytro 121", mpi supercharger,star suspension setback kit,oft steering relocate,all new front and rear metal bushings.
currently waiting on parts for a 144" long track kit - campoplast challenger 144x15x2", tracks USA tunnel extension,muffin works 11.5" tipped rail extension,mtx hyfax
Hello everyone, I'm new here; looking forward to sharing information with others knowledgeable on the subject of Yamaha snowmobiles. I am -currently waiting on a
-144"X15X"2" camoplast challenger
-tracks USA tunnel extension
-muffin works ltd 11.5" tipped rail extensions.
For extras on my sled I already have
-stage 1 mpi supercharger
-oft relocate
-no slip drivers
-star suspension setback kit (121"-128"?)
-09 nytro spindles
The question I need an answer for is, will the tipped extension work well with my 144" track even with the setback kit? I would assume the figment would be fine, but I've heard that tipped extensions can throw it off, all advice appreciated!
-oft relocate
-no slip drivers
-09 nytro spindles
Rob Flanagan
- Nov 18, 2014
- 2008 Yamaha Nytro
My one brother and I did almost the same thing 2 years ago and we just got done doing it to my other brothers Nytro as well. All are 2008 Nytros.
What we did was Purchased a Skid relocation kit, rail extensions, tunnel extension, extrovert drivers, (Hartman Inc) 2" tracks and a bunch of other stuff too but the main thing that we did was upgrade our Subframes.
I can't emphasize enough how important this is especially if you plan on taking your Nytro out boondocking. Hell, my brother bent his subframe and arms going over a railroad track! (ouch)
Also, what we did was go with a 136" rail extension with a skid relocation to push the skid back to fit a 144 x 2" challenger track.
Since we went with the 2" track, we also went with 8" extrovert drivers. (Wahl Brothers) to clear the larger paddles.
I could go on for day about what we all did to our Nytros so if you have any questions, don't' be afraid to ask.
Yamahaaddict08
- Dec 11, 2016
- Maine
Perfect thank you man! I certainly could use all the advice I can get on this. I'm just hoping all this stuff will fit togatherMy one brother and I did almost the same thing 2 years ago and we just got done doing it to my other brothers Nytro as well. All are 2008 Nytros.
Rob Flanagan
- Nov 18, 2014
- 2008 Yamaha Nytro
First off, like i said before, i would strengthen the subframe. So either you take your stock one out and either weld in new plates/gussets in the correct spots or you buy a new one. We like to tear things apart so we welded plates in to my subframe but my brothers subframe was way too messed up to straighten out so he ended up buying a different one (2012 i think) at HayDays and had it powdercoated. This website is an awesome resource for information so you can pretty much find anything about your sled.
I would Start Here:
http://ty4stroke.com/threads/fx-nytro-faq.58910/
I would Start Here:
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Big question. Did you just order 144 tip up extensions and go with 144 track then get relocation separate or did you inform them that you were relocating the skid (4" back) when you ordered the rail extensions. As they would be totally diff set of rails
Rob Flanagan
- Nov 18, 2014
- 2008 Yamaha Nytro
We talked to Tom @ hartman Inc, Great guy, you could talk to him for hours about Nytros/Set-up.
NO, we did not order the 11" tip up extensions, We went with the shorter, straight extensions (technically for the 136 setup i believe) and the relocation kit.
See Here:
http://www.hartmaninc.com/catalog/n...ustom-long-track-kit-144-skid-relocation.html
I have to warn you....Once you start tearing apart your sled....your going to say.
"Well, i might as well do this (insert something not needed) while it's torn apart this far" then the nest thing you know your garage looks like the pic on the right.
See Here:
Pfnytro144
- Aug 2, 2015
- Antigo, WI
- 2018 Yamaha Sidewinder xtx se 137
My brother is right but the 11 inch extensions will not work along with the relocation kit for a 144 inch track you'll need to get the 7 inch extension and I have a set I just don't have the hyfax extensions to go with them
Yamahaaddict08
- Dec 11, 2016
- Maine
Thank you for the replies guys, the sled as it sits already has the setback kit for star suspensions, I just recieved the tipped up 11.5" (121"-144")rail extensions and I'm waiting on the 144"X15" trackBig question. Did you just order 144 tip up extensions and go with 144 track then get relocation separate or did you inform them that you were relocating the skid (4" back) when you ordered the rail extensions. As they would be totally diff set of rails
Yamahaaddict08
- Dec 11, 2016
- Maine
Ohh I see, I've been wondering how the relocate kit affected the geometry, I figure it wouldn't be worth taking the relocate kit out and slamming the 144" setup under it.My brother is right but the 11 inch extensions will not work along with the relocation kit for a 144 inch track you'll need to get the 7 inch extension and I have a set I just don't have the hyfax extensions to go with them
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I think you need longer track because your going from 128-144 not 121-144. Hope right rails are on way but that's only issue I saw that may arise
Yamahaaddict08
- Dec 11, 2016
- Maine
Awesome write up! I certainly will be calling up my welding buddy and grizz who I hear great things about.First off, like i said before, i would strengthen the subframe. So either you take your stock one out and either weld in new plates/gussets in the correct spots or you buy a new one. We like to tear things apart so we welded plates in to my subframe but my brothers subframe was way too messed up to straighten out so he ended up buying a different one (2012 i think) at HayDays and had it powdercoated. This website is an awesome resource for information so you can pretty much find anything about your sled.
View attachment 123826 View attachment 123827
I would Start Here:
Yamahaaddict08
- Dec 11, 2016
- Maine
Unfortunately I'm not sure I can return any parts other than the rail extensions, the track,tunnel extension and mtx sliders I bought on eBay private sale.I think you need longer track because your going from 128-144 not 121-144. Hope right rails are on way but that's only issue I saw that may arise
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
That's fine tunnel extension will be correct, if you want 144 you just need to contact extension company and ask they will have Dept with it to know the right ones. Like has been said I think they use the 136" extension with the relocate kits to get 144
Yamahaaddict08
- Dec 11, 2016
- Maine
Awesome thank you, can I trouble you for some picture of your sled to get an idea of the look?We talked to Tom @ hartman Inc, Great guy, you could talk to him for hours about Nytros/Set-up.
See Here:
View attachment 123850 View attachment 123851
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Muffin works is member of site here and I'm sure you could get in touch and straighten it out too! Great people an products
