thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Hi everyone I am up ridding and doing final tuning of my SC I am getting terrible fuel mileage and am running about 10-10.8 when just cruising how high can it be low and mid range?Top end it is 12-13 so I think that's good there but I want to cruise and still get some miles out of my tank. Only getting 60-70 miles per tank not hammering on it.
Sent from my XT1564 using Tapatalk
Zuki1216
- Dec 9, 2015
- Indiana
- 08' Apex LTX
07' Attak MPI S/C
Mid to upper 13s to be safe.
Sent from my SM-N910V using Tapatalk
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Thanks zuki
Welcome to the Supercharger world.. they are pigs. WOT is too lean for my taste. But cruising is to fat. I would rather see at WOT at no more that 12.2 or high 11s and cruising with low boost and little to know load you can by in the high 12 and low 13's
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Thanks Tom I will bring the top down too then. I expect it to be a pig but would like to get cruise to the highest safe level as that is where I spend most of the time running thru the Twisties and such don't use much more than 1/4 throttle with this beast.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I got her up to almost 9 mpg and was not being easy on her. I think I can get her tuned in from here. One last question is it okay when carrying 70mph or so thru some relatively straight woods trails if you see 13.6 at times?
What boost are you seeing at that MPH and RPM?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
7-9000 rpm 4-5 lbs of boost
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I have yet to see it hit 8 lbs so I think I have my pulleys correct
Just cruising at that speed with zero load, should be fine, keep an eye on engine temp.. if its t00 lean, engine temp will spike.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
No temp gauge yet. Thanks for the help.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I think I am safe
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
She is running like a well oiled machine.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Is there a way to adjust just the low mid range? Like from 1/8-1/4 throttle that is about 70 mph or so and she is running 12.9-13.8 then I hit the throttle more and holding around 90 plus mph and it is perfect 10.2-10.8 should I be concerned as I spend a fair amount of time running in the 70-90 mph range.
Sounds fine to me. Watch the engine temp.
