savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
Just was wondering with those short headers that it may make room for the cat bigger fuel tank? i know my buddies 600 cat has a bigger tank and id love to gain some range. Im not sure if header change would be enough to make it work or not but thought id throw it out there.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Hmmm, that got me thinking, are you sure, I already carry a mountain addiction 3.3 gal can .
savageman69
- Apr 21, 2014
am i sure what? i ride with a 2014 6000 cat and yes his tank is bigger without a doubt...we get the same mileage but he has more range
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
That some cats have bigger tanks.am i sure what? i ride with a 2014 6000 cat and yes his tank is bigger without a doubt...we get the same mileage but he has more range
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
2014 AC 6000- 12 gal
2014 Viper- 10.6 gal
ask google..
ask google..
savageman69
- Apr 21, 2014
yep thank you like i said....it would be a big bonus to do the header if i could squeeze the bigger tank in too2014 AC 6000- 12 gal
ask google..
tapex_07
- Feb 15, 2009
I agree. But I think the issue is the fuel pump. The bigger 2 smoke tanks aren't fitted with the fuel pump and fuel level holes..
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
2017 Zr 6000 spec sheet says 11.7, is it worth the extra 1.1 gal, didn't check price.
savageman69
- Apr 21, 2014
2014 is 12 gallons....i would like do it if possible2017 Zr 6000 spec sheet says 11.7, is it worth the extra 1.1 gal, didn't check price.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I have the straight line shorty header, would be a nice addition if price is right, and it was a full 2 gallon's.
savageman69
- Apr 21, 2014
then for argument sakes lets take the 1100 turbo tank...or 1100 n/a tank should be fitted with holes for bothI agree. But I think the issue is the fuel pump. The bigger 2 smoke tanks aren't fitted with the fuel pump and fuel level holes..
savageman69
- Apr 21, 2014
savageman69
- Apr 21, 2014
tapex_07
- Feb 15, 2009
Idk, looks like the fuel pump is molded into the tank but not cut out. And the location for the 1100 pump is way up high where the fuel filter is on the Viper. Guessing you'd have to either make the pickup work from a cat or cut the hole in the tank. Plus the level gauge would have to be cut in.
The first one you posted http://www.bd-xtreme.com/index.php?id_product=73&controller=product doesn't appear to have the molding for the pump in our stock location. And the tanks that are labeled 12 gal are actually 11.7 gal, but 13 gallons would be nice tho!
- 146K
