ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Ok found it...I was gonna go with BRP and crimp them in like many did last season, but I think these are cheaper then the BRP.
YAMAHA -- SMA-8LR21-50-00
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
Yep - that's the whole kit - comes with all 3 pieces, screws, and adhesive to do the install.Is that the entire kit needed? I believe its 3 pieces for rear exchanger.
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Thanks!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
The stock protectors from cat or Yamaha don't require the skid removal.get the protectors from full power performance they just slide on and bolt to back you don't have to take skid out to do them
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
X2. I put two sets on last year. Took less than 10 minutes. Don't have to remove anything.
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
Just remember to run the screws in and out of the protectors once before installing them or else you will have a very hard time threading them in. Also make sure you have decent ventilation that glue smells wicked.
lilrez
X2
shawnj
What is the part number for the remainder protectors that go all the way to the front? For a 2022 ltx
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
They OEM's don't offer them. You must go to the aftermarket for those.
shawnj
Ah ok. Can I just get a one piece that covers the rear heat exchanger and the tunnel or do I still need two different pieces ( on each side of course)They OEM's don't offer them. You must go to the aftermarket for those.
Thanks.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
STM has options on that.Ah ok. Can I just get a one piece that covers the rear heat exchanger and the tunnel or do I still need two different pieces ( on each side of course)
Thanks.
Thats where I bought mine from.
The guys that run higher speeds recommend running the track tight. No sage of track off rails with rear end lifted off ground.
shawnj
I was looking on their site, I got confused with what I was seeing. Think looked at too many sites on the heat exchanger/ tunnel protectors today. I wonder if skid needs to come out for the full length ones..?STM has options on that.
