DJ Hennessy
- Jan 30, 2016
- Barrie, ON
- 2016 Yamaha Viper RTX SE
2006 Yamaha Apex RTX
Hi,
I have a 2006 apex rtx, found this loose wire after reassembling it from doing oil change and a-arm bushings... Don't remember pulling it off and not sure if maybe its an accessory wire left by previous owner???
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Definitely aftermarket or some sort of add-on. Does it have Yamaheaters?
Grimm
Yeah, it looks like an aftermarket wire. Maybe it was for a temp gauge or a fuel controller.
Did you trace the wire back?
snowman 700
- Oct 10, 2005
- Mid-Michigan
- 2011 Apex SE
2012 Vector (wifes)
Hi,
Add on for something. The blue connectors it is hooked to are aftermarket to tap into a wire without cutting the wire. I would disconnect or tape up everything to avoid it grounding out if it is a power tap.
DJ Hennessy
- Jan 30, 2016
- Barrie, ON
All taped up, everyone answer I've gotten is after market wire... Guessing last owner had something on it they took off. Thanks everyone for your help!
