curtis arsenault
- Jan 11, 2016
- fox creek ab
- 08 yamaha apex mtx
I cant stay off revlimiter clutching is all stock secondary was set to 6 and 1 tried 6 and 3 also and still as soon as i go to wide open throttle its right to rev limiter that is on groomed trail and in 2 feet + of powder 162 2.5 paddel track any help with this would be greatly appreciated
Is the tip of the clutch fly weight empty? or does it have a 13.3 with a holes in it. Inner should be empty. Will it bang the limiter once it hooks on hard pack?
curtis arsenault
- Jan 11, 2016
- fox creek ab
Ya it hooks up and still limitter if i let off a little bit it will come off limiter and keep pulling
I would toss a 4.5 g in the middle
curtis arsenault
- Jan 11, 2016
- fox creek ab
What colour spring is stock for primary and secondary this is my first 4 stroke i just bought a few weeks ago guy i bought it from had since new and sad it was stock but just curious
curtis arsenault
- Jan 11, 2016
- fox creek ab
What do ya mean by thatI would toss a 4.5 g in the middle
Yellow -pink-yellow primary and white secondary see below and clock on your year.
http://www.totallyamaha.com/snowmobiles/AAATuning Chart/Specs.htm
Rivets:
http://www.totallyamaha.com/snowmobiles/aaTECH/drivespecs/Rivets_Rollers.htm
Rivets:
curtis arsenault
- Jan 11, 2016
- fox creek ab
Most of my riding is going to be on trail to
and what should i have my helix set to its at 6 and 3 now
one change at a time.. leave it set as is and make the rivet change first.
curtis arsenault
- Jan 11, 2016
- fox creek ab
Ok so how to i put the rivits in do i remove the weight one at a time and tap the rivit in
curtis arsenault
- Jan 11, 2016
- fox creek ab
And my primary spring is black now and secondary is black with a blue or grey paint mark on it in the middle
curtis arsenault
- Jan 11, 2016
- fox creek ab
And when you say 13.3 on tips is that the 13.3mm 3.1 grahm rivits in outer holes and if so do i leave them in plus put the 4.5 gram im middle
If you dont have the experience to make the changed maybe it would be best to have someone else make the change for you. The middle hold is filled with a peened over rivet that needs to be drilled out partially and then pounded out with a punch. A new 4.5 G rivet added to that hole and then peened into place. The weights will have to be removed to do this.
cacsrx1
You need to tell us what weights, rivits, springs, helix, and your elevation before we can give you much help.
curtis arsenault
- Jan 11, 2016
- fox creek ab
Everything in clutches i was told is stock and its around 3000ft elevationYou need to tell us what weights, rivits, springs, helix, and your elevation before we can give you much help.
