cacsrx1
You really need to verify what you have, a lot of factory parts "look" the same but are not. Every hole in the weights should have a rivet in it.
curtis arsenault
- Jan 11, 2016
- fox creek ab
- 08 yamaha apex mtx
curtis arsenault
- Jan 11, 2016
- fox creek ab
curtis arsenault
- Jan 11, 2016
- fox creek ab
cacsrx1
Put a 4.5g rivet in the empty hole and back the helix setting off to 6-1.
curtis arsenault
- Jan 11, 2016
- fox creek ab
Im running the yamaha belts last night i pulled my weights out to check them and cleaned the clutch tried it and same thing so i put my new spare belt on just to see and it stays off revlimiter now would it be possible that it was the belt the issue the hole time
Yes it would.. now it works fine?
curtis arsenault
- Jan 11, 2016
- fox creek ab
It seemed to ya it would hit limiter once or twice only insted of all the time at wot
I would still add a few grams to that open hole.
cacsrx1
X2......really no need for it to hit the limiter.I would still add a few grams to that open hole.
curtis arsenault
- Jan 11, 2016
- fox creek ab
What should i put in the open hole for grams
Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
What 2.5 inch track ?I cant stay off revlimiter clutching is all stock secondary was set to 6 and 1 tried 6 and 3 also and still as soon as i go to wide open throttle its right to rev limiter that is on groomed trail and in 2 feet + of powder 162 2.5 paddel track any help with this would be greatly appreciated
curtis arsenault
- Jan 11, 2016
- fox creek ab
go back to the listings that I posted that showed the rivets you can get and add about 2 grams.
