BLH
- Mar 18, 2017
- Wisconsin
- 2016 SR Viper LTX-SE
2023 Sidewinder 137
Any good options for this on a 2016 LTX-SE? Seems like the plastic factory ones are useless. I ride all trails in WI/MI but still concerned.
I don't like the Yamaha rear skid because it's a ton of work to remove for oil changes and would be blocked by my lift. Seems like someone should make something.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
I run this plate.
http://www.barnofparts.com/skid-plates-new
Considering this for the chain case.
https://racewerx.myshopify.com/products/brake-chain-case-guard-prochassis-2012-2014-all
BLH
- Mar 18, 2017
- Wisconsin
2023 Sidewinder 137
Funny - I have that same skid plate here ready to install.
I hadn't seen those other guards. They looks nice - expensive though!
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
$100+ cheaper than a chain case. And much easier to install.
Peace of mind payoff is 55 cents/day over the course of a year.
After that, you get to decide what else to spend $200 on.
You know there's always something.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
i have a few ideas. hope to have something developed for next season.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Not surprising! Keep us posted. I'm interested. Enjoyed my skid plate this season.i have a few ideas. hope to have something developed for next season.
09nytro
I like both of those , I'm going to get those for my sled for sure
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
The Yamaha/AC rear skid plate only takes about 5 minutes to remove, the 10 extra mounting bolts are easy to access with the side panels off.
There is a post in FAQ which shows how to cut a access panel in accessory rear skid for oil change. Works slick and great protection.
BLH
- Mar 18, 2017
- Wisconsin
2023 Sidewinder 137
FYI, the racewerx one is no longer available so I'm still looking for options.
TD Max
Just put the poly skid plate on and you'll be fine.
BLH
- Mar 18, 2017
- Wisconsin
2023 Sidewinder 137
Sucks since I already have the barn of parts plate. I guess it looks like that can be used together with some effort.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
I looked at a ton of different setups, then i talked with a guy from grip and rip racing about the skidplates they ran on their cats when they ran in cains quest. After hearing his recomendations, and seeing the abuse one of my riding buddies has put on one, i deciding to go with the rpm composite carbon fiber skid plate.
In my opinion,It is hands down the best protection you can get. but, if you think removing the cheap plastic yamaha skidplate is a pain you will absolutely hate this skidplate. It is much more work than the plastic yamaha plate
If you search my posts you can find more info if you are interested. By the way, its expensive, but i believe it is worth every penny.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
In my opinion the race works really don't gain you much more protection over the original. Plastic is pretty tough. The key to protection is dispersing impact and gliding over objects versus getting caught. The chaincase protector has a rather squared off leading edge. Rotor side isn't as bad but could be improved. I'm working on something to supplement existing guards that will disperse impact and allow glide action up over object.
For simple clarification think of a ski. If leading edge of ski is formed at a 90 degree angle do you think it will glide over a log? The protectors on chaincase and rotor need to function the same as a ski.
BLH
- Mar 18, 2017
- Wisconsin
2023 Sidewinder 137
Yikes - $650
- 32K
