Rodney
my sled with 1400ks on it with no chain case leak, in the same spot all summer.i spun the track by hand last week ,and now I have a chain case leak WTF..
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Is it leaking out the back on the seal? This seems strange for sure.
Rodney
No I looked , I think its from the bottom right bolt.Is it leaking out the back on the seal? This seems strange for sure.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Check the vent at the top of the chaincase to make sure its not plugged.
Its located inside the tunnel at the top of the chaincase.
Try to stick a small flexible wire through it to make sure it is venting.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I know there's a lot of people with 2016 that leak from the cover. It was an issue this time last year. Doesn't really make sense that you got 1400 Kms of no leak though
Don't stick anything in the vent. There is a checkball with a spring in there. A shot of brake clean and a hose that you can suck and blow into is the way to go. I think many cases leak a little almost just sweating oil. The oil clings and then eventually drips. That's when you see the leak. I would clean the vent and case then see if it's doing it again.Check the vent at the top of the chaincase to make sure its not plugged.
Rodney
Tha
Thanks Cannondale I will try that..Don't stick anything in the vent. There is a checkball with a spring in there. A shot of brake clean and a hose that you can suck and blow into is the way to go. I think many cases leak a little almost just sweating oil. The oil clings and then eventually drips. That's when you see the leak. I would clean the vent and case then see if it's doing it again.
Rodney
Ya the ball is moving mabe is was stuck when I 1st spun the track no leaks now. tksTha
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
Oops thats right. Forgot about the checkball in there. Thanks for clarifying that for him.
Rodney
Thanks guys no leak so far!!Oops thats right. Forgot about the checkball in there. Thanks for clarifying that for him.
waldo1
mine leaked - had to remove cover - cleaned it and ran a file like a straight around case - put silicone on seal - no leaks.
zrcrazy
2015 XTX. 175 miles chain case leak covered under warranty
Rodney
Still leaking its going to the dealer2015 XTX. 175 miles chain case leak covered under warranty
That sucks. Worth the try though.Still leaking its going to the dealer
bleedyamaha
- Sep 28, 2013
- Northern Iowa
My Viper I had is leaking oil again. Went back to the dealer for warranty. They said they had to replace both sides and have $ 700 in parts. They said it's covered in warranty but my nephew has to pay labor.. Isnt warranty suppose to cover everything???? Checked a little further into it. The YES card says 48 months expiration say 2018. I year warranty plus 4 more. All straightened out. They thought it expired in Dec 2017. No harm no fall.
