Gyukonrick
Does anyone know the procedures to change the meter from miles to KM? I did it on my 07 Grizzly but cannot find the prodecures to do it on my 07 Phazer and Apex.
Len Todd
Gyukonrick
Try what?????
Gyukonrick
Got it...thanks
Len Todd
Did you get 'er figured out?
Gyukonrick
I did. I'll try it today.
Gyukonrick
Well, I tried it. It didn't work. I was able to change the time but that's it..
08PhazerRTX
i did it on my Phazer RTX . you select ODO and hold down on the select button for up to around 15 sec .
It should work worked for my first time i tried !
hope this helps
Thanks Peter !
hope this helps
Thanks Peter !
Gyukonrick
I'll try it on the Phazer but the Apex does not have an ODO button.
in the manual(section 5-15) it says select the odo mode and push the select button for 10 seconds while the snowmobile is stopped.
I'm pretty sure you have to have the machine running for it to work.
I've changed all mine since 03.
Gyukonrick said:I'll try it on the Phazer but the Apex does not have an ODO button.
You don't have to have it running to do this
Go through the SELECT MODE untill you see the ODO in the window of the Gauge Cluster, then Hold down Both Buttons the SELECT & RESET AT THE SAME TIME for about 10 to 15 seconds it will go to the opposite that it is set at now.........U R DONE
