Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
DO NOT EVEN CONSIDER DOING THIS MODIFICATION UNLESS YOU WANT TO BUY A NEW MOTOR. THIS WAS AN IDEA I PICKED UP FROM ANOTHER FORUM MEMBER AND I REGRET POSTING THIS. I AM NOW LOOKING FOR A MOTOR.
This automotive PCV is available at Autozone part number PCV1175DL and priced around $3.70. This neat little idea was discovered by forum member stingray719 and he tested it and it works flawlessly. Original post started by Stingray and his successful test here Stupid question
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
How do you use it?
Ruggybuggy
- Sep 1, 2013
Cubby said:How do you use it?
It's used on the vent hose of the oil tank so when you roll the sled on the left side the oil does run into the airbox.
Cubby
- Dec 14, 2009
I might have to give that a try.
Thanks.
Thanks.
stingray719
Ruggybuggy
- Sep 1, 2013
Hey Stingray, did you grind the "hex" part of the valve off? Looks like you cut the hose then managed to push both side of the hose together so you only had to use one hose clamp.
stingray719
Ruggybuggy said:Hey Stingray, did you grind the "hex" part of the valve off? Looks like you cut the hose then managed to push both side of the hose together so you only had to use one hose clamp.
Was missing a clamp so I did that, I went back and put two clamps on.
Ruggybuggy
- Sep 1, 2013
Thanks for the reply. Just to be clear threaded side towards the air box?
For Canadian shoppers use Napa part # UNI 29358.
Here is a list of what the valve fits:
Buyer's Guide
Make Model Engine Year(s)
Chrysler 300M 2.7 L 167 CID V6 DOHC 24 Valve 2000 - 2001
Chrysler 300M 3.5 L 215 CID V6 SOHC 1999 - 2004
Chrysler Concorde 1993 - 2004
Chrysler Intrepid 1993 - 2004
Chrysler LHS 1994 - 1997
Chrysler LHS 1999 - 2001
Chrysler New Yorker 3.5 L 215 CID V6 SOHC 1994 - 1996
Chrysler Prowler 2001 - 2002
Chrysler Sebring 2.7 L 167 CID V6 DOHC 24 Valve 2001 - 2004
Dodge Intrepid 1993 - 2004
Dodge Stratus 2.7 L 167 CID V6 DOHC 24 Valve 2001 - 2004
Eagle Chrysler Vision 1993 - 1997
Plymouth Prowler 3.5 L 215 CID V6 1997 - 1997
Plymouth Prowler 3.5 L 215 CID V6 1999 - 2001
Napa US part number MPF 39358
[web]http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/PCV-Valve/_/R-MPF39358_0177454245[/web]
Buyer's Guide
stingray719
Ruggybuggy said:Thanks for the reply. Just to be clear threaded side towards the air box?
Buyer's Guide
Check ball end UP so it can breath.
Ruggybuggy
- Sep 1, 2013
Thanks for the correction. For the record, THREADED SIDE GOES TOWARDS THE TANK
This should be a sticky.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Has anybody flipped their Phazer upside down with this PCV installation with a positive result?
Ruggybuggy
- Sep 1, 2013
weldion said:Has anybody flipped their Phazer upside down with this PCV installation with a positive result?
Have a read of the original thread. stupid question
Stingray tested it in the parking lot with good results.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
For whatever reason, I didn't get notifications on updates to that thread. Good to know it works. The only other thing needed is a tether. I used an Arctic Cat normally closed switch which works well. Just spliced into the ignition switch wiring.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Ruggybuggy said:weldion said:Has anybody flipped their Phazer upside down with this PCV installation with a positive result?
Maybe you can edit the first post in this thread with the info that stingray made a successful test by tipping the sled over?
Ruggybuggy
- Sep 1, 2013
Edit completed.
Hey Mooseman, do you have a part # for the AC switch and the application? I had looked before but all I could find was normally open switches.
