TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
I have came up with a design for a fold down bench for an enclosed snowmobile trailer. Depending on how much you find the parts for they cost around 25-80 to build and work very well. I will post a video later today on how the work but here are a couple pictures. There is one snowmobile part used anyone recognize it?�
So so basically I use 1.5" angle iron to use for the mounting attachment on the wall, the ctc is perfect for the studs. Then use 1" light wall square tube to for the front leg. To keep it from slipping out when down I drilled holes through the floor and screwed big fender washers, then welded 1/4" bolts that stick through the bottom leg and go into those holes. To keep it in the storage position just use more angle iron and a tarp strap to hold it in place. The top of the snowmobile part is covered with 5/8 plywood, then wrapped with cheap indoor/outdoor carpet and carriage bolted into place. Easy to build and works great. Reason I built these I didn't like the price of anything on the market. I will post all the dimensions on the front leg and pictures of how to weld up later. Just helping out fellow sledders. Oh yeah and if you haven't guessed what part it is it comes in various lengths ...skidoo xm rear bumper. Cheers
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
So I mount the 1.5" x3" angle iron mounting brackets 17" from floor to centre for bench height, the front leg is 1" light wall square tube(0.65 I believe). I cut 3 pieces 16.5" and weld together so my outside diameter is 16.5". Then drill a couple 1/4" holes through the bottom and weld 1/4" bolts with a stub sticking out to go into floor. Then where it mounts to the bumper I grind the corner so it's rounded and doesn't catch when folding....I use the mounting riv nuts in the xm bumper to mount to the wall and to the leg. Then trace the bumper onto a 5/8" plywood and cut it out...leave it a bit short from the wall. Then staple indoor outdoor carpet to the board and mount to the bumper with carriage bolts. As for keeping it in place I mount 1.5"x3" angle iron on each side ...take the hooks out of a tarp strap and bolt one side and the other have a long bolt to slip it over. Pretty much it. Big fender washers screwed to the floor.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Looks good
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Nothing better then poking fun to the doo guys about their bumpers are useless bumpers but make great seats.
Nice work and great idea!
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Having a seat in the trailer is huge. Nice job.
Now you will need a coat rack with a series of hooks to hang your stuff on.
MS
MS
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
I do have some
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Ya - you got it covered. Nice rig.
Makes the trips so much more convenient when everything is set up properly.
MS
MS
