- Apr 14, 2003
- Hessel, Michigan
Because of the latest belt blowing issues.....it seems like the ones that are blowing belts do not have the washer or shim behind the secondary.
This offset is important for belt alignment, without the washer, it's putting too much pressure and heat on the fixed sheave.
The dimension for the correct offset is 58.1mm -61.1mm.
- Apr 14, 2003
- Hessel, Michigan
krm
- Apr 22, 2016
- ny
Mines 60.3 mm with no shim from the inside of the drive to the outside of the driven ..With the shim i'm 61.3 mm
buyrite01
No not the problem no shim here from day one and turned up to 255 hp and over 500 miles clutches are just warm and still clean.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Curious what your offset is?No not the problem no shim here from day one and turned up to 255 hp and over 500 miles clutches are just warm and still clean.
we all want to find a solution to the blown belts and we have this awesome community here willing to help so if everybody(more importantly with a blown belt) could check their secondary spring for signs of binding we can figure this out with process of elimination. And NOS this is in no way an effort to undermine your thread! Your help here is Greatly appreciated by yours truly.
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
One of the first things that I checked when I brought my LTX-LE home was the clutch offset. I was surprised to see that there was no shim behind the secondary for offset. Once I checked the offset using the recommended method in the owners manual I found that my offset was exactly 60.0mm or exactly right in the middle of the recommended specification between 58.1-61.1mm.
It's surprising to read that some SW's are being delivered with a shim behind the secondary clutch and some are not. I find it very unfortunate that in the manual there is no mention if there is supposed to be one there or not. There seems to be a lack of consistency in what's being delivered on the sled.
To my knowledge there is still no factory clutch specs regarding optional tuning parts (springs, weights, helix's, etc) for our SW's. What's up with that Yamaha
Just a heads up.....for anyone who wants to order either the 1mm offset shim (#8JP-RA448) or the 2mm offset shim (#8JP-RA449) I found out recently from my dealer that the 2mm shim is on BO from Yamaha until sometime next month but the 1mm shim is currently available.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Interesting, thanks for the update on your end and about your sled at deliveryOne of the first things that I checked when I brought my LTX-LE home was the clutch offset. I was surprised to see that there was no shim behind the secondary for offset. Once I checked the offset using the recommended method in the owners manual I found that my offset was exactly 60.0mm or exactly right in the middle of the recommended specification between 58.1-61.1mm.
**sj**
What happens if a guy is beyond the range?
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Yeah I am ~61.4mm
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Yeah I am ~61.4mm
From what I have seen with mine you are ok. Your better off to that side or the tolerance than the other. JMO
john10toe
Removed my secondary today.....found no shims installed at factory. I was immediately concerned but I checked the offset and it is right in the middle of the specified tolerance. No evidence of binding but marginal roller contact on helix on 2 of the ramps.
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
ordered 1 each from babbits on the phone yesterday, shims are on the way, already left MI per tracking, get em maybe tomorrow or saturday. rode about 20 miles earlier, pulled over to check adjustment, first real ride with adjuster kit, top of nub even at top of sheave, secondary warmer than primary. could keep hand on but twice as warm. didn't check again when i got back home.
- 6K
- 46K
- 32K
