Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
So, I was able to make a couple speed runs, in less than favorable conditions. speedo indicated 120. Definitely could have pulled more. No biggie. Snapped a pic of primary. What is it trying to tell me? Any comments would be appreciated!
SledFreak
- Feb 7, 2005
- Ontario. Canada
I would say that its all good. However, I would clean your primary... Clean both clutches and belt with scotch brite and acetone. It also looks like your slepping up top a bit. Its hard to tell, hoever, you are close to the top. I would say on a hard lake or road, you would be right at the top of the primary.
Doc Harley
- Oct 17, 2016
- Here & there
Thanks, sledfreak! Will get it all cleaned up. Hoping for one more good ride this year........
**sj**
shows you are what, a 1/4" from the top...so you seem to be shifting out all the way...
Doc Harley
- Oct 17, 2016
- Here & there
I will have to measure and get back to you Steve? Looking at the pic, maybe closer to 3/8ths. I will verify. Just didn't want to clean things b4 you guys got a look at it. I will look at both springs as well.
SledFreak
- Feb 7, 2005
- Ontario. Canada
looks 1/4 to me..
- Apr 14, 2003
- Hessel, Michigan
Looks ok.
Doc Harley
- Oct 17, 2016
- Here & there
Right on guys. I really appreciate the input. I'm on here learning more & more each time. Going to get things cleaned up and ready to party....
Thank you so much........ Joe
newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
looks good.
How many miles? All stock clutching?
Doc Harley
- Oct 17, 2016
- Here & there
A/C rollers in secondary is all......No flat spots on factory rollers, but thought, what the hell.
650miles
650miles
newtron
- Jan 2, 2010
A/C bushings in secondary is all......No flat spots on factory bushings, but thought, what the hell.
650miles
Right on.
How are your rpms up top say around 105 mph on loose snow? mine drop off quite a bit on loose snow! Not as bad on hard pack
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
You mean rollers right?A/C bushings in secondary is all......No flat spots on factory bushings, but thought, what the hell.
650miles
Doc Harley
- Oct 17, 2016
- Here & there
Right on.
Not enough seat time over 100mph to form an opinion either way.
Yes and fixed.
How's your journey been Joe?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Is your helix shimmed? My primary was showing slight rubber near top of primary sheaves, shimmed helix and no more rubber.
- 11K
