DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Your slipping like "greased lightening".. And the crazy part is it looks to me that your slipping the whole shift out.. What belt? Stock sled? Studs? and mods to clutching?
DMCTurbo
- Nov 12, 2005
Stock 8JP with 650 miles on it, Ulmer clutch kit, 1.75 track, no studs, stock ECU, stock exhaust.Your slipping like "greased lightening".. And the crazy part is it looks to me that your slipping the whole shift out.. What belt? Stock sled? Studs? and mods to clutching?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Your secondary could be binding? Check secondary spring and rollers.. You could have flat rollers? .. I would say something in your secondary is causing it.. Or you need more squeeze from your primary clutch.. The stock primary weights have shown to slip belt.. As they do not "squeeze " as well as some aftermarket weights. Your secondary is et at 3/3 ? or 6/1 ?
DMCTurbo
- Nov 12, 2005
Sorry forgot to add I have CAT rollers, stock helix and at 3-3.Your secondary could be binding? Check secondary spring and rollers.. You could have flat rollers? .. I would say something in your secondary is causing it.. Or you need more GRIP from your primary clutch.. The stock primary weights have shown to slip belt.. As they do not "GRAB" as well as some aftermarket weights. Your secondary is et at 3/3 ? or 6/1 ?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
That's a lot of slip either way IMO.. Secondary issue is where my money is
**sj**
fwiw a 1.75" track is big load...and gearing down further is a benefit..especially if off trail often
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
How do you get more grip from the primary clutch ?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
More aggressive weights. Softer belt compound.How do you get more grip from the primary clutch ?
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
Do you mean make them heavier, if they are adjustable, or a different profile ?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I was referring more to the flatter profile weights(stock). Compared to the aggressive/banana shaped weights... The posters 1.75 track is maybe causing some issues for sure also
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
Thanks for this info.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
You MIGHT(rpm's is factor) add more weight(certain areas) to a adjustable set if you see black marks in certain areas on clutch surface. BUT > This guy is slipping all over the place IMO..
Yam4Strokin
If the belt was slipping that bad you'd have way more belt dust on the clutch and engine IMO. I think the flash of the camera is making it look worse than it is. It appears the clutch moveable sheave (what you can see in the picture) is clean as well as the motor. If it was slipping that'd all be covered in belt dust.
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
When was the last time you cleaned your clutches? Also, do you have any oily residue dripping down from the clutch cover and onto the primary via an oiled filter)?
I'd clean everything up (if you haven't done this previously since new) with a rag and acetone on your faces, and keep a close eye on this moving forward (at least you'd have a good reference point, as there are so many variables as to why this could be happening)....I'd also clean up the belt (if you're going to continue running it on clean clutches)...
