Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Might not be a bad idea to get the plugs out and inspect them for fouling because of the failed start attempts. Definitely dump out the old gas and add fresh premium fuel. Prime it several times to circulate this new gas into the system before trying to start it. Check the oil for gas smell. After two years, it should be changed regardless. After getting it started, the coolant should be changed as it's probably original. Same with gear oil.
Iammoresnow
- Jan 11, 2012
All above done except for coolant. Had not figured it would be bad. Might be worth a check. At the correct level in the res.as well. Sled had a mouse house in the exhaust. Big poof upon startup! Still a bit of junk to pull out. Hate to burn it up! 37f and rain here today. Good thing I bought another sled. Should about assure that winter will stay away..... Guess I can store another one.
