ApexGTman
- Jan 8, 2006
- Newfoundland
- Hers - 2017 Sidewinder XTX LE
His - 2015 SR Viper RT-X LE MPI Turbo with Ulmer Stage II Clutch Kit
2012 Apex SE
2006 Apex GT, Stage 2 Ulmer Clutch Kit, Ulmer Stealth Mod Air Box, 144 1.325" Woody's
2003 - RX1
1998 - SRX
1993 - Exciter SX
1992 - Exciter II
Last night I had a problem with my '15 Viper RTX LE with MPI Turbo. The coolant temp fluctuated from normal 72C to all numbers from 2C and in between causing the low temp warning to come on and the machine to stall. I have taken off the cable and I am wondering if there is anyway someone can suggest to test the sensor or the cable? My dealer will have to order the sensor but with it being so intermittent with the fluctuations it seems to be more of wiring issue than anything else.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Sounds like temp sensor..
Yamadog
My 14 used to do that and go from 50 to 195 f once at wot it shut off but then stopped doing it. I have noticed in my videos the red warning light flashing while the bar graph is only shiwing 2/3rds .
Studroes144
Mine was doing same thing, never went low enough for cold temp light to come on but would fluctuate 40-50 degrees either way from normal operating temps. $10 temp sensor solved the problem
