mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
Tried my new Curves out last weekend. Trails in Gaspe had a few inches of loose snow, and some areas were harder packed. First 100 miles or so I was darting quite a bit. Added about 1/2 an inch of preload to front shock, and presto...no more darting and very minimal push in corners the next 200 miles. Will take a little preload out for next time. Overall, very impressed w these skis. Tuners hanging in garage.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
What carbide are you running ms
Sledboy
MP5, Ditto x2 with me. I had to lighten the heavy steering. on day 3 on a sled trip and switching sled I noticed holly crap my curve's take an ape to steer. so I dropped limiter strap to longest setting and added more center spring preload==> problem solved!
Curves are amazing! I run 4" round bars.
mp5
- Feb 14, 2011
- 09 Nytro XTX
6" carbides
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Just bought a set also, running 6" carbide, big improvement over stock with Bergstrom triple points.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
How is steering effort.
I drove a viper with curves and although the ski had a crisp bite on the trail the steering effort was evident.
MS
MS
On mine with 4" bars and straps all the way out, effort wasn't bad at all, but I'm also a big guy so I've got a lot of leverage. Never rode it with stock skis so can't make a comparison.
Last year I put a mountaintech front on it and pulled the strap up one hole, and still very comfortable steering effort.
mp5
- Feb 14, 2011
- 09 Nytro XTX
4" bar risers here. Steering is good...little effort, but I had to add pre load to my front skid shock to take a little pressure off the skis...but only to help with the darting I was having. Worked much better
Anyone running the leading edge on their curves?
dremmick
How many threads are exposed on your center shock? I have the curves and they are very hard to steer even with my limiter straps at full length.
I just cranked my center shock up all the way. Had about 1/2" but still wanted reduced effort. Don't be afraid to crank it down. I am only 180lbs, didn't notice any change in the stiffness on the rear.
dremmick
I already have it cranked up where this a 1" of thread showing.
I have no thread showing now. Max preload on my spring.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I'm going to be testing curve skis with snow trackers end of this week. The snowtrackers really lighten up steering effort on stock skis, and am hoping they will do the same on the curve skis.
- 40K
