DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
Hey all,
I realize the dealer will do this for free if a bring the machine in. However, my phazer is currently stripped down as I am trying to isolate an issue with getting spark on only one cylinder. While doing so, I realized this machine may not have the grounding block update done.
The TSB (attached) says that if there is a translucent 6-pin connector installed, then the update has been done. This machine has the 6pin connector. However, it also shows that there will be a new ground cable to the battery. My machine doesn't have this secondary ground cable, only the single, from-the-factory connection.
Can I simply order the parts for this update and do it myself? Do I even need to bother, and just create a new ground on my own? The TSB isnt clear where is new ground is connected to so if someone can enlighten me, that would be great!
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
Nevermind, I found the part number and ordered it. For 8 bucks its just easier than bringing it to the dealer
1bad10tacoma
- Oct 20, 2015
- Maine
- 2007 Yamaha Phazer GT
1988 Yamaha Bravo LT
1986 Yamaha Bravo ST
Not sure if mine had the update , what does the updated part look like?
1bad10tacoma
- Oct 20, 2015
- Maine
Forget it found it
Sk1pp3r-808
- Dec 13, 2016
- Cooks Creek
- 2008 Phazer RTX
2001 Z120
2002 Z120
- Manitoba
Take a couple pics during the update and put on here.
YamahaHoss
I just got an 06 RS Venture--and yes--charging problems--what does the Ground Block Update look like and where located please?Not sure if mine had the update , what does the updated part look like?
MikeWalters
Instead of the update I hardwired several grounds (including headlights and rad fan) directly to battery (-)
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
The update applied for 07-08 Phazers, VLs and MPs only.I just got an 06 RS Venture--and yes--charging problems--what does the Ground Block Update look like and where located please?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
Yep, I got the melted wires on my MP late in its life and rather than waiting for the parts, I just made my own too.Instead of the update I hardwired several grounds (including headlights and rad fan) directly to battery (-)
