tproteau
- Sep 28, 2014
- Wpg Manitoba
- 2003 Yamaha Rx-1 LE Liquid Silver
1998 Polaris XC 700
2007 Ski-Doo MXZ Adrenaline 800 HO
I purchased my sled (03 rx1) with heelclicker 2 speeds and the black primary spring. I wasn't given any of the adjustable weights when I took ownership of the sled.
I recently found a good deal on a set of drag n fly weights in my area with both the white and black spring and all adjusting bolts.
1st question: are the adjustable weights for 2 speeds the same as the dragonflys?
My sled was stock last winter and it never pulled much over 10k rpm from a dig. I gutted the exhaust this summer, added 165 mains and I'm removing plastic in the airbox slowly to get the perfect mixture.
Question 2: For those with experience with these weights which do you recommend for aggressive trail riding.?
I liked the way the 2 speeds pull but if the dragonflys are better then I will spend my time tuning those.
Thanks in advance for any opinions and insite you can provide.
