Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
Bought my sled used. It has about 7000km on it. I noticed the drivers are very worn. Is this an issue? Can I have them reversed on the shaft? Thanks.
The extrovert nubs do wear quick and the wear just causes more drag. I see no reason you couldn't swap them but they are cheap new.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Ok thanks, I haven't priced them out yet.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
As always Cannondale, you are right! The driver sprockets are 1/2 the price of the aftermarket ones that I put on my Nytro.
Thanks for the help!
On a side note, is there a tutorial on everything involved with a track change, or do I have to piece it together from the FAQS? That's a pile of reading!
Just have to piece it together from FAQ. May want to consider getting rid of extroverts. Intros are inexpensive also. Prepare yourself for replacing whole Assy. Either way. I would take it apart before ordering parts for inspection. Driveshaft brake side bearing likes to eat the shaft surface.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Shoot! Thanks for the heads up...
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Holy crap, the axle assembly is $500 up here! Is there any cheaper alternative? Can the shaft be saved?
Yes it can be saved. If real deep weld and turn down to correct size. If only slight wear just peen it. Some use Loctite. I tried that and had a heck of a time removing Caliper the next time.Holy crap, the axle assembly is $500 up here! Is there any cheaper alternative? Can the shaft be saved?
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
OK, sounds good. Did you use a center punch to peen it? Thanks very much for the help!Yes it can be saved. If real deep weld and turn down to correct size. If only slight wear just peen it. Some use Loctite. I tried that and had a heck of a time removing Caliper the next time.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
If you could use a yamaha part I would price it out ! I found yamaha parts 30% cheaper up here in Canada than some cat parts.
Yes use a punch. Extroverts should be available through YamahaIf you could use a yamaha part I would price it out ! I found yamaha parts 30% cheaper up here in Canada than some cat parts.
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
Noted, thanks guys!
Kkurz
- Nov 1, 2016
- Peterborough On.
(Yamaha powered)
I talked to a buddy of mine and he offered that I could have the shaft welded to build it up and turn or grind it to spec. I figured that if the shaft is screwed, I could try that. I'll get the new bearing and use that for fitment measurement. It shouldn't need to be pressed on I assume..?
Right. Should just be a nice slip fit. No play but bearing should be able to go on and off with your hand.I talked to a buddy of mine and he offered that I could have the shaft welded to build it up and turn or grind it to spec. I figured that if the shaft is screwed, I could try that. I'll get the new bearing and use that for fitment measurement. It shouldn't need to be pressed on I assume..?
