Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
Just bought a new 2.25 Power claw track for my apex mtx, I currently have 4000 km on my apex now, and I was wondering if it's time for new drivers? If so what should i go with? Avid? Crracing? Any help will be appreciated. Thanks
kingtut
There is a person on here that sells extroverts pressed onto the shaft. Also depending on the year of your apex he also sells the newer stock one that is model to fit the older apexes. I believe it is hibshaman from barn of parts. If you can't find him here Google it.
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
Oaky thanks I'll look into it
le700
Avid are supposed to be good.
typically any drivers that are white plastic are cnc made, alot stronger & cost more. the black plastic are blow molded, cheaper to make. they work for 99% of the sleds. is your apex boosted? if so avid is the way to go. pretty sure cr is just selling avid drivers. i have avid drivers on my boosted rx1 & boosted nytro. work great
le700
Also rxrider uses BRP with good results on his turbo sleds, so those must be good too.
kinger
BRP and avids are the best, although I don't think you can get the doo ones any longer so that is why I had to go to the much more expensive Avids.
princesledalot
- Feb 8, 2006
- East Pouce
- 04 RX1 13 apex se 96 vmax 4 aerocharged
- Pouce Coupe BC
Can a person re use avids that were previously on another shaft ?
