MyOutdoors
I'm finally getting her back together! I lucked out and met a guy who locally owns his own shop and does vapor blasting and cerakoting. Big difference from when I started with all the salt corrosion. Basically bomb proofing her with a plethora of BOP.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
OMG, you did yourself a huge dis-service coating the oil tank and intercooler. you just insulated parts that should dissipate heat. Never ever want to coat the intercooler for certain.
MyOutdoors
I was worried about that but after looking into Cerakote, I went for it. I plan on checking temps compared to stock. Worst case scenario is I'll have it all vapor blasted and leave it. Brian from MotoTech is the go to guy for YZ motors and has been using cerakote on just about everything...motors ,cases, radiators, air cooled motors, etc. This isnt ceramic or powder coating. It's a 1mil coat.OMG, you did yourself a huge dis-service coating the oil tank and intercooler. you just insulated parts that should dissipate heat. Never ever want to coat the intercooler for certain.
KnappAttack
- Feb 19, 2004
- Welch MN
Is Cerakoat not ceramic?
Ceramic is an insulator. Just saying. I wont even paint an intercooler with a thin spray. The mfgrs of the good intercoolers even tell you not to paint them.
MyOutdoors
Cerakote.com - Global Leader in Thin-Film Ceramic Coatings | Cerakote
Cerakote is a global leader in the manufacturing of thin-film protective ceramic coatings. Specialized finishes for Automotive, Aerospace, Industrial, Consumer Electronics, Sports & Fitness and more. Browse our Gallery, locate a Certified Applicator, or contact us about your coating needs.
www.cerakote.com
Definitely not ceramic...this coating is no thicker that the original stock black. It can be used where tight tolerances are needed.
earthling
Cerakote is a global leader in the manufacturing of thin-film protective ceramic coatings. Specialized finishes for Automotive, Aerospace, Industrial, Consumer Electronics, Sports & Fitness and more. Browse our Gallery, locate a Certified Applicator, or contact us about your coating needs.www.cerakote.com
Definitely Ceramic, it says so right in the link. Ceramic is an insulator, it is also very hard which is why you can get away with a thin coat. It has many good properties, convection is not one of them.
Cerakote is a brand name, and anyone referencing Cerakote is talking about the same thing so just google Cerakote and insulation and you will run across links like this.
Jet Hot Vs. Cerakote: A Detailed Comparative Study
As car enthusiasts, we all appreciate the beauty of a well-maintained, high-performance vehicle. An integral part of this involves the use of high-quality coatings for engine parts to enhance their longevity, performance, and aesthetics. Two of the most popular coating options that often cross...
glennsaid.com
Or Cerakote and Ceramic
What Is Cerakote? Top 6 Cerakote Questions Answered
Have you been wondering 'What is Cerakote?' and why it's quickly becoming a top customization and coating technique? Learn more about Cerakote from R&B Arms.
www.rbarmsusa.com
It is ideal for surfaces that are inert and not active (like your handlebars) but on an intercooler it is exactly the opposite of what you want.
MyOutdoors
It does have ceramic as part of a composite. If I see temps above normal, I'll pull it and vapor blast it...or get a new one. This coated one was pretty corroded from the previous owner and figured it was worth a shot.
Cerakote does make a heat dissipating coat I see now in either black or grey?
earthling
The arctic black is what you want, it is a thermoset (polymer) resin coating, no ceramics.
sideshowBob
Don't forget to do the rollover bypass before you are done.
MyOutdoors
It's on the bench awaiting install.Don't forget to do the rollover bypass before you are done.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I like it....Very cool!
