canadianhunter
We have enough to ride, we are busy marking and grooming and warmer weather is coming. Looking good.You should have good snow this year to get it out and about. Especially if you keep going south.
Keith Furst
- Jan 17, 2015
- sr viper
I opted for the new flash even though I've had zero issues. I'll post back when I find out if my good starting machine stays that way after flash.I have been very happy with the flash update on my horrible starting 2014. Since the flash, no kickbacks and it started in temps down to -15. I have done it on both my 14 and 15. Strangely they seem to start more often on the first crank when colder than warmer temps but like most commenting here they now may take two cranks to get it fired up.
saskieXTX
- Nov 24, 2015
- Saskatoon
- 2015 Yamaha SR-Viper XTX
1997 Yamaha Vmax XTC 600
Got my 15 XTX back. Was about - 20c last night unloading the sled. Let the fuel pump cycle, cracked a little longer than usual but fired and ran first time. Seems to idle slightly better also. Less hunting.
Sent from my SM-G935W8 using Tapatalk
Allan
Checked with my dealer and they called Yamaha and they have the new updated flash for speed. But the person from Yamaha told them on the phone there was no real problem with the speed lol
Now I wonder if I should get it done on my 2016 stx dx 146?
I had no problem's with the machine in 8000km . so am I just asking for problem by doing it?
sk-rx1
Unfortunately anyone who reads this sight has to have reservations about anything yamaha says lately. Too many different stories and a general denial of real issues people have experienced.
Jipper
- Mar 3, 2015
- Ramsey,MN
- 2016 Yamaha Viper LTX LE
Had mine done last week and took it out for the first time today since the update and it runs fine and the speedometer seem to be correct.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Speedo is bang on now..
canadianhunter
Had my 14 Viper flashed yesterday, Jan. 13. This morning -17 C started with couple seconds of cranking and warmed up fine. Doing trail work with a lot of warm starts, let system cycle then crank. Many starts and it would only start on second try with as much or more cranking than the cold start. Tried a bit of throttle, didn't help. Finally tried going right to crank, no cycle sometimes starts right up and some times takes couple seconds of cranking, but does start on first try.
Speedo and gps are within 1 kph, very good. Odometer and gps are very close, usually within 0.1 km depending on slippage.
alain459
Had mine done and it runs fine and the speedometer seem to be correct.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
Has anybody else seen any performance gains with the updated flash? I thought I read someplace somebody saw an increase in RPM redline somewhere around 9350 and also seemed to have a snappier response.
I have a 2014 LTX SE and have never experienced a starting issue and it starts awesome every time regardless of temp from -25 F to +40 F. I'll be up by my dealer for a little over a week and debating to do or not to do.
jeffgilbert
- Dec 17, 2007
- Newfoundland
- 2019 Sidewinder BTX LE
I just had mine done and it works fine cold start needed one try one time and 2 another and hot was faster then before idles slightly better i think and a little higher as far as i could tell sped was good ill try more the weekend with gps.
toddszr600
What dealer Todd? My speedo is off by about 15km/hr and odometer is almost 30kms out...
Been gone for a bit, Dakar was on
Deaaler is Podolinsky outside Petrolia, havent managed to get mine in yet either.
srvfan
- Nov 9, 2004
ha anyone installed hotter plugs ? since this motor seems so rich with this flash
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
Interesting, my sled is quite a bit leaner through the whole rpm range. I'm seeing it on my wide band o2 and noticeably better fuel mileage.
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
I had my 7000 flashed, it starts easy, one or two attempts, doesn't seem to be a specific pattern. I didn't have a chance to try it out in temps below 10 F, Vermont had a warm winter. My speedo was 9mph off. Cat sent me a flyer saying to bring it back in if the speedo was off. They reflashed it again, that fixed the speedometer issue. I love this sled, I hope this flash fixes the starter kick back. I did clean and polish all battery terminals and wires in the starting system and covered them with di-electric grease. I don't know I feel that will help with anything but it gives me peace of mind.
