Float skid in a Nytro..I have the front mount template from Yamaha if interested!
edge_232
Age
50
Madison WI
2011 Nytro MTX slowly being modded
2005 IQR Trail Converted
I know the float skid into a Nytro has been beat to death but I have & will share the front mount template produced by Yamaha. Yamaha actually made a light weight float retro-fit conversion kit for the Nytro MTX. As typical from Yamaha this kit was way over priced & the light weight kit was too light weight for "hard use". Anyways this template bolts into your stock FTA hole & the rear toe hook mount which then it gives you the pilot hole for the Float FTA mount! The template has a left & right side to it so all you do is flip it to the correct side & your set. Now the Yamaha template is only good for the MTX Nytros but I made a new one that also has & can/will also utilize the FTA mount point of the XTX as well (which I believe is the same as the RTX). Now you will need to relocate your RTA mount points as well. Which I made my own drop brackets based off the Yamaha retro fit kit. If your interested let me know & I can post a PDF that can be printed off on a 8.5x11 sheet of paper to make your own.
Interested to see what you have for the XTX, would definitely download for future use!
I’m also interested aswell!!!!
