FX Nytro MTN FAQ
MrSled
Site Admin/CEO
Staff member
Age
54
Schofield, WI
Website
www.totallyamaha.com
2020 Sidewinder SRX
Clutching
How to install a Ulmer Clutch kit
Torque Specs
Drive Shaft Torque Specs
Electrical
Starter System trouble shooting
Nytro Fault Codes and Relay Location
Install Vector Gauge on Nytro
Install Vector Gauge on Nytro Ver2
How to test my AEM Air Fuel Gauge
Fluids
Oil Change Instructions
Oil Pressure-Diagnosing engine after loss of oil
Fuel Mileage
Fuel Level in Tank for each bar on gauge pod
Fuel Mileage Reports from TY Members
Real World Fuel Mileage
Fuel Tank Options
Clear Tank: extra fuel and installation with pictures
Extra Fuel Tank
Removing Fuel Tank Sleeve
FX Nytro Miscellaneous
General Bearing Maintenance
Bearings: Jackshaft and Trackshaft
Feedback - Apex Owners Switched to Nytro
Feedback - Phazer Owners Switched to Nytro
Owner Photos
Sled Weight and Horse Power numbers
Top Speed
Who Loves Their Nytro!
Wire Rub Fix with Picture
Yamaha Technical Manual On-Line Order web site
Handlebars
Handwarmer Fix from Bluballer
Handwarmer Poll
Handwarmer Resistance Tests on 09 Models
Kill and Dimmer switch Part #'s
Headlight
Bulb Size
Headlight beam adjustment procedure
Hid vs Halogen
Hyfax, Belts
Adding wheels to XTX for better hyfax wear
Belt Options
Hyfax wear opinions
Left Boot Syndrome
Fix for Wet Left Boot Syndrome
Wet Left Boot Discussion
Modifications
Under Tunnel Exhaust Seat Mod
Front End Ball Joint
Install Heated Shield Hook Up
Removing heat exchanger with pictures
Spare Belt Holder
Tether Installation Instructions with Pictures
Tool bag
Ride Report
Alaska Early Season 2007 Ride Report and Second Ride Report
Member Test Ride Report
Official TY Ride Review of 2008 FX Nytro
Yellowknife's Season Ride Report
Shocks
Adjusting GYTR Dual-Clicker shocks
Fox Floats: Pros and Cons
Fox Float PSI Setting Survey
Skis
Mod to install a Polaris Gripper Skis
Best Skis?
C&A's
C&A's with picture of mounts
Suspension
XTX Suspension Setting
08 to 09 Suspension Changes
09 Changes
Crucial Suspension Changes to Make Your Nytro Rock!
Limiter Strap Fix
Need help getting a softer ride
RTX Suspension Settings - I nailed it!
Suspension Settings That May Help
FX Nytro settings POST YOURS
Suspension Troubleshooting Chart from Snowest Magazine
Tracks
Understanding Track Length and Pitches
Adding Extrovert Drivers
Track or Gear Change Instructions with Pictures
Track or Gear Change 2nd Thread
Track Options
Windshields
Pictures of tall windshield and side deflectors
XTX Specific Threads
Suspension Settings
MrSled
Thank you for taking the time to put all this stuff together in one spot. Sure makes it easy for the rest of us ;)!
bholmlate said:
MrSled
Your welcome, that Moderators do a lot of this too... always thank them as well.
