Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Well.......more than one question.....
So, it's been said that the Sidewinder runs out of steam at appx. 122mpg at 8900+/-?
Is the gear what the problem is? Can it run faster with a gear change, while otherwise staying stock?
Lastly.....I turn it up to 250h/p and 9500rpm....with stock gear what's the appx. Top speed.
Easy stuff for the guys that have been there.
Thank-you, Joe
Thank-you, Joe
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
If my lake ever freezes I'll tell you where it just bangs the limiter over and over on glare ice. I was hopeful but it all thawed out again a couple weeks ago.
newtron
- Jan 2, 2010
- 2020 900 ACE Turbo, 2019 SRX, 2018 850 X
Might have a track plowed this weekend on our lake. Will post the results.
Will be some 850's there as well!
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
Might as well plow all the snow onto another track for the 850s because all I hear is how good the 850s are in deep snow lol
newtron
- Jan 2, 2010
Nah
I'll just plow a separate 600 ft track for the 850's. Apparently that's what measures real power. Lol
Maybe I'll plow a 2 ft track as well. I'm sure my sons mini 120 srx will compete with my SW making it as fast..... right?? Hahahaha
Doc Harley
- Oct 17, 2016
- Here & there
Go on dootalk. They make the 850 sound like a Sidewinder killer!
And to be honest, I have no idea. I don't own an 850 nor have I raced one.
And....I didn't buy the Sidewinder to drag race. Happy for guys that did. I hope it's quick as well as fast.
I bought mine for the rush.....no disappointment here. And when I do get bored, I know where to go......
75northface
- Oct 26, 2016
- Sudbury, Ontario
- 1997 Mach Z
Just make sure to plow a little pit area for the 850s so they can access their blown engines too
thebest
I hit 123mph or 199km/h at 9400 rpm and blow a belt in the trail at the limit of the gear I have the td powertrail , now I need gear ! Lol
jpr-ltx-dx 2015
- Sep 21, 2014
- sr viper ltx dx
i have try 24/41 all other thing stock and did not get more than 118mph,and all stock whit stock 21/41 hit the same 118.so the only thing that have change is I lost a lot in acceleration.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ya,you just geared up a lot over stock,if I can find a 40 bottom I will match that with a 22 top soe 22/40 vrs 21/41 stock which has seen 128 mph gps w/tune,and generally in stock form sees 121 gps that is stock gear ratio.i have try 24/41 all other thing stock and did not get more than 118mph,and all stock whit stock 21/41 hit the same 118.so the only thing that have change is I lost a lot in acceleration.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Good luck finding a 15w hyvo 40 bottom. Unless you use a 13w then they're available.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
why no one makes a 15 wide 40,heck I have a 39 bottom in 15 wide,wonder if its spline matches up,its a poo bottom gear,poo and yammi always used same spline,but this is cat/yammie now.Good luck finding a 15w hyvo 40 bottom. Unless you use a 13w then they're available.
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
Do you have part number for a yamaha 40t 13w hyvo bottom gear?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes,you would be with stock power,to haul that gear ratio on snow from corner to corner you would need more power either eco or powertrail,or someones 250 plus kit.i have try 24/41 all other thing stock and did not get more than 118mph,and all stock whit stock 21/41 hit the same 118.so the only thing that have change is I lost a lot in acceleration.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
No everdently they don't make one yet for that huge spline on the yamacat shaft.Do you have part number for a yamaha 40t 13w hyvo bottom gear?
- 7K
