CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
I’ll start by saying I’m still on the original battery with 11,300kms. Voltage is still 14+ and I always connect it to my optimate tender after a ride.
Sled almost always starts in the warm shop, but with hesitation. After it starts and runs throughout the day, it usually fires up right away.
If it’s out in the cold, even like -5 the sled becomes a nightmare to start. No kickback, sled has current flash, just cranks and cranks and cranks and won’t start for like 5mins of cranking. Then when it does decide to fire, I get a nice backfire, then it usually starts after that.
I’m thinking I’ll replace the battery for next season, maybe that will help, I have no idea. Anyone know what might be wrong or how I can possibly resolve the starting issue? Thanks!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
The valves need to be adjusted is my guess. I rode with a 2017 viper for 3 years and what you described is EXACTLY what it did. His would start terribly when cold and then it would run on two cylinders after you cranked on it forever.. Eventually straightening itself out after warmed to temp.
. He had the valves adjusted, and believe they were to tight(not within spec). After the service was performed it was better not perfect but better. Make sure you take it to someone/dealer that has good service and knows what they are doing as it seems service is iffy these days.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Do the valves really need to be adjusted so soon? I didn’t think they needed to be adjusted until around 25000-30000kms?The valves need to be adjusted is my guess. I rode with a 2017 viper for 3 years and what you described is EXACTLY what it did. His would start terribly when cold and then it would run on two cylinders after you cranked on it forever.. Eventually straightening itself out after warmed to temp.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
The sled I refer (2017) had around 4K on it.. I guess the question becomes do you want it to start and run on all 3 cylinders when its -5?Do the valves really need to be adjusted so soon? I didn’t think they needed to be adjusted until around 25000-30000kms?
This issue (cold starts) and running on 2 cylinders is common and I would bet Yamaha knows what it is.. What amazes me is that a company known for quality engines didn't make it right for the years this was a issue.. I know they had flashes and most did NOT work, and even made some sleds worse.. Pretty sure they know its the valves and didn't want to cover the massive labor hours to make them right> so they tried with different fuel maps.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I believe they were wrong(valves) from the factory in some years on that engine.adjusted so soon
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
'18 SR Viper RTX (SOLD)
'20 Poo XCR 850 (SOLD)
Manual states service around 25K I believe but seems to be an issue from as low as 4k and up. I would start with a fresh battery though. These seem to be very subseptible to any low voltage conditions.Do the valves really need to be adjusted so soon? I didn’t think they needed to be adjusted until around 25000-30000kms?
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
The bad valves I believe were in the 16’ vipers. My sled runs great, like the day I bought it. Just doesn’t want to start in a bit of cold weather. I’ll start with a new battery and go from there. I have noticed just this past season it is cranking a bit slower than usual.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
It’s not the battery. Good luck.
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
Softer connecting rods started in 2016 and led to some turbo'd issues. I don't think the valve tightening was year specific.The bad valves I believe were in the 16’ vipers. My sled runs great, like the day I bought it. Just doesn’t want to start in a bit of cold weather. I’ll start with a new battery and go from there. I have noticed just this past season it is cranking a bit slower than usual.
WillowAce
- Jan 21, 2017
- Northern Wisconsin
- 2016 Viper L-TX-DX - Sold
2019 Switchback XCR - Sold
2015 Viper L-TX-LE
2019 Renegade 850 - In the shed just in case
2020 Viper L-TX-SE
I assume you have checked your plugs and made sure you are getting a strong blue arc when grounded and turning over? If the valves are adjusted correctly and you are having starting issues other suspects would be fuel delivery or spark. Since you are starting and running fine after warming up I would check the rectifier output. Remember the battery doesn't provide current directly to the plug wires the rectifier converts DC to AC. If the rectifier is starting to go bad it might not put out enough AC current to turn the starter sufficiently to crank a cold engine.I’ll start by saying I’m still on the original battery with 11,300kms. Voltage is still 14+ and I always connect it to my optimate tender after a ride.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
I haven’t checked my plugs and should probably just replace them as well, along with the battery and go from there.
Yamasledder
- Mar 7, 2010
- Brandon, Manitoba, Canada
- 2020 Viper LTX SE
It's really not a big job to check the valve clearances on these. You only need to remove the valve cover and take measurements with feeler gauges. The real work comes if you find out that they are out of range.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
I used to have to check the valve clearance on my old 2006 yzf 250. That required it like every 30hrs lol.It's really not a big job to check the valve clearances on these. You only need to remove the valve cover and take measurements with feeler gauges. The real work comes if you find out that they are out of range.
I just assumed it was a pain in the a** getting in there
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
It lied. My 2014 went tight at 6500 milesManual states service around 25K ...
WillowAce
- Jan 21, 2017
2015 Viper L-TX-LE
2020 Viper L-TX-SE
All of Yamaha manuals lied to me. Viper, Grizzly, and Viking and I've had cold start problems with each caused by tight valves. All before the 2,000 mile mark to boot.It lied. My 2014 went tight at 6500 miles
- 13K
