MT.man
Allen,
I thought I read somewhere that you offer a heavy duty drive shaft with extrovert drivers for 06-09 apex's ? I didn't see them on your web site could you give me some info if you offer such a thing.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
OEM Shaft (1.0625" hex size) with 9 tooth extrovert drivers installed: $301
Heavy Duty Shaft (1.25" hex size) with 9 tooth extrovert drivers installed: $361 (this would be a "heavy duty" replacement with a little larger hex size)
MT.man
Allen,
Thanks I just received the front end bushing kit that I ordered monday ( great service )
One question on the drive shaft, is it a bolt on with no worries of contacting the front of the rails ? I do have a fully cliped track.
- Apr 17, 2003
- Menno, SD
- Menno, SD
You will be fine with the Monoshock suspension, but if you have a 2007 to 2009 Apex RTX then you will have to trim the front of the rail for the extroverts to clear.
MT.man
Thanks,
I have an 06 apex so I should be all set. Its good to get this out as there seems to be a market for a stronger shaft than what the oem offers. This might be a fall project
kinger
Hey ulmer if I send you my stock driveshaft with 9T doo extros can you get them on that big upgraded shaft? Is it a micro belmont?
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
What drivers do you use Allan? Do you sell them separately?
kinger
He used to use Whal and I read he will be going to Avid drivers this summer.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Kinger, I should be able to get your old drivers on the HD shaft without any problems. Yes Micro builds the shafts.
Phazernut, they are Wahl drivers currently. They are $150 for the pair of drivers seperately.
kinger
Thanks man I will get them out to you and be upgrading to the HD shaft for next winter.
